My external harddrive become raw for my computer
ropper2112
I have used the same external harddrive for over a year but suddenly my computer cant se what on it. It has the letter "N" but shows as raw. Its strange becours it works fine on XP pro and it did work fine on this comp before. Anyone have a clue?
Ardneh
ropper2112:
You should copy your data from the external disc to XP first.
The external disc will likely need to be wiped and reformatted.
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
whs
I second what Ardneh says. Save your data and reformat it. You seem to have trouble with the MFT - and that, to my knowledge, cannot be repaired.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
usasma
Old and cranky
I just lost my W-D external drive yesterday - and it displayed the same symptoms.
Take the advice above and backup immediately!!!
Run a hard drive diagnostic on the external drive (available from the external drive's manufacturer).
