My Volume Level goes down on its own
Deagles
6
My Mic Volume Level goes down on its own
i have installed and updated all my drivers. i got IDT High Definition Audio CODEC. my problem is that my Volume Level in Control panel-Sounds-Recording-Microphone(Properties)-Level, goes down when ever my voice gets louder. is there a setting or a program i have to get through to make it not automatically lower it self? i Already Unclicked "Allow applications to take exclusive control of this device" from Exclusive Mode. this only happens on MSN and maybe other programs that are similar. but not on Ventrilo.
591
Location
United States
Go to google, and type in: My Mic Volume Level goes down on its own
And click the fist couple of links other than this website's
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 linux ubuntu partition
    1 vista partition
    1recovery partition
    1 windows 7 partition
    1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Smurfyy
Danny :)
1,083
Location
Essex, UK.
heyy, Deagles, try the audio and video setup in msn. msn changes the volume of your microphone according to your voice, say you was talking loud it would change the microphone volume level so you dont deafen the person on the other end, and vice versa. The only thing i can suggest is to set the default volume to half way, then adjust it while in convo..
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    1 128GB Kingston SSD Now OS drive
    1 250GB sata main drive.
    1 160GB from old install.
    1 500GB for re-directs from OS disk.
    1 Seagate GoFlex External 1TB with backups.
    750 watt.
    Foxconn TSAA699.
    4 fans.
    ASUS EEEPad Transformer 16GB with Dock w/32GB class10 SD |
    Dell PE1950 II / 2xDual Core Xeons @3.00GHz / 16GB RAM / PERC 5i/R / 2x36GB SAS OS - 2x1TB SATA Data both RAID 1 |
Deagles
6
:DYes i have changed it from custom and Default to Disable and it does not lower my volume at all no more. Thank you so much again now i wont have to minimize while we play lol
Smurfyy
Danny :)
1,083
Location
Essex, UK.
#8
Heyy,
Nice to know you got it working!
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
