Mystery BSOD problem
SpinMan918
Hello,
I had my friend build a pc for me in 08. It started out fine, but after a while, it would bsod every once in a while when i was playing total war, or civ. Now, every time I play a game, it bsods. I've gotten replacements for my ram, which didn't do anyhting. When I first got the computer the startup was extremely fast, but now it takes a long time. Anyone have any suggestions.
stoneys-nutz
Gamerholic
Hello SpinMan918,
Follow the link from theog, upload your dump files and we will take a look at them, hopefully we will be able to tell you what is causing your BSOD's.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
stoneys-nutz
Gamerholic
This is the result of your bugcheck.
STOP 0x0000007F: UNEXPECTED_KERNEL_MODE_TRAP
Usual causes: Memory corruption. Installing faulty or mismatched hardware. Device drivers. SCSI/network/BIOS updates needed. Improperly seated cards. Incompatible storage devices. Overclocking. Virus scanner. Backup tool. Bad motherboard. Missing Service Pack.
As you can see, there are a lot of possibilities as to the cause.
If there is anything overclocked, set it back to default.
Until this is fixed, un-install the AV software. (don't forget to re-install after).
The memory you have fitted, is it on your MB manufactures QVL
Is there an update for your Bios ?. If you install a Bios update, use a USB flash drive, not any update software through the OS.
Can you confirm you have all the Windows updates installed ?.
Read this tutorial, it will show you how to check your drivers.
How to identify a buggy device driver on Windows Vista | Vista Rewired
Also, unplug all Devices, leave just mouse and keyboard.
Do you have any AMD tuneup software installed ?.
Update your CPU driver, you may need to go to your manufactures site for that. You need amdk8.sys driver.
I will check your driver dates when i get a bit more time and let you know if any need updating.
Theres a bit to get you going, run through the list and post your results, good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
SpinMan918
Unfortunately I'm not tech savvy enough to understand everything on that list, but i'll do some googling and get my friend that built the pc to help me out. I'll let you know when I'm done. Thanks.
-Spin
SpinMan918
something i forgot to put in my first post: When i run hot cpu tester, it bsods after a while. Also, one time it crashed, it started up in dos and the hd dumped a bunch of corrupted files. hope this helps in the search.
-Spin
stoneys-nutz
Gamerholic
I would update this driver first. amdk8.sys driver.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
SpinMan918
I've looked on the internet and can't seem to find it. Its not on AMD and some forums that popped up said its third party. Any specific websites that i should check?
-Spin
stoneys-nutz
Gamerholic
File AmdK8.sys is located in the folder C:\Windows\System32\drivers.
Take control of the folder and put the file straight in there.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Ed Canuck
Power User
Upload the latest Minidump file.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE
    1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
stoneys-nutz
Gamerholic
Go into your BIOS and disable the C1 State for the CPU. There should be an option under the CPU section to allow it, or not allow it, to enter C1 state and other various power saving modes.
Try this and post your results.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Katokato
Banned
I'm a beginner at this, but from reading the minidump file, it seems that a 3rd party software caused the amdk8 driver to fail.
Do you have driver verifier enabled? If so, then disable it.
Sorry if i make a stupid mistake but im just learning here.
DEFAULT_BUCKET_ID: VERIFIER_ENABLED_VISTA_MINIDUMP
MODULE_NAME: amdk8
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are.
Heres a nice article on driver verifier: http://www.edbott.com/weblog/?p=576
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm
    1 linux ubuntu partition
    1 vista partition
    1recovery partition
    1 windows 7 partition
    1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
SpinMan918
Stoneyz-nuts, i couldn't find the C1 setting in my bios.
Katokato, I think verifier tuned off. I ran it before, mabe it's still on. I'm not sure how to turn it off though.
stoneys-nutz
Gamerholic
What is the make and model of your motherboard ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
