need a HDD
7vis
37
hi all.
i wanted to buy a new HDD for my laptop. but i wanted to know if it will be compatible with my system.
i want to get a 320GB HDD @7200rpm
Specs: HP pavilion entertainment pc DV4-1220us
AMD 2.1ghz turion X2
ATi radeon HD3200
4gb ram
250 HDD @5400rpm
i want to know if the motherboard will support a larger and faster HDD.
    amd 2.1
    4 gb
    ati radeon HD 3200
    SATA 250gb 5400rpm
    15mbp
2,456
Location
NY USA
hi all.
ATi radeon HD3200
4gb ram
250 HDD @5400rpm
7vis
Are you looking for an internal or external HD? Im sure your mobo will support almost 3 times the size you want to get. Just want to make sure its from a good mfr (western digital, seagate,etc) with a decent warrenty and that it runs the same protical as your mobo (ide, ata, sata, etc)
try to get as big as you can afford cause you would think that 320 is alot bigger than a 250 but its not. Storage rew's double every 18 m onths
Good luck and ask questions
Ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
lemur
1,533
Location
University of Kentucky
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
7vis
37
I want to get an internal HDD im not sure but i think 500GB is the largest i can get which is cool. what i really want is is "SPEED" as i already have a external drive 1TB.
Thats why i was asking if my mobo can support a HDD @ 7200rpm.
were can i find this out?
Ken[/QUOTE]
    amd 2.1
    4 gb
    ati radeon HD 3200
    SATA 250gb 5400rpm
    15mbp
2,456
Location
NY USA
Ken
[/QUOTE]
7vis
Im sure your mobo can run 7200 but you should check with HP about what the largest they recommend. No matter what HD is the largest you can put in and they do run warmer. HD's (except for flash drives) are not going to speed up your computer alot.
Good luck
Ken
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
