Need flash player, can't download it. Help!
amplid
Vlaming
Power User
I want to play call of duty 2 again, but I haven't got flash player installed on my pc anymore since I got Vista. Anyone know a good patch because every time I download flash player from the adobe website, I either get nothing at all or can't find the program except in my 'programs and features' on the control panel. There I see the flash player icon, with a BIG RED CROSS in the upper right corner and I'm sure it's not supposed to be there.
Some help plz:p
Amplid
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
roy69
47,65,65,6B
Make sure you download it using the 32bit version of explorer. Flash is not compatable with 64bit versions.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
amplid
Vlaming
Power User
And how do I know with what version of internet explorer I'm downloading it?
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
roy69
47,65,65,6B
The 64 bit version tells you it is 64 bit.
To be totaly sure, use a different browser to download it.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
amplid
Vlaming
Power User
Okay so my Vista is the 64 bit version, so internet explorer is 64 bit too. A different browser is like Mozilla or something, right?
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
amplid
Vlaming
Power User
Roy, I just installed it with Mozilla Firefox and just like in internet explorer it installed in less than 2 seconds....? Here's the icon I get when I open my programs and features window on the control panel:
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
roy69
47,65,65,6B
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Brink
Staff member
mvp
#8
Hi Amplid,
You can check what version of IE7 your are in by clicking on Help and About Internet Explorer. As Roy posted, it will have 64 bit listed of you are, otherwise you are in the correct 32 bit IE7.
You might try the Adobe Flash Player uninstaller program to remove it from your computer first:
How to uninstall the Adobe Flash Player plug-in and ActiveX control
then see if it will install from here:
http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash&promoid=BIOW
Hope this helps you,
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
amplid
Vlaming
Power User
#9
Huh, Brink it says I have 256 bit...
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
scrooge
Vista Pro
#10
anyone no why Flash is not compatable with 64bit versions yet?
will thay be making a 64bit version?
scrooge
    Intel Core 2 Duo E8400 / 3.00
    ASUS P5K-E/WIFI-AP LGA 775 Int
    G.SKILL 4GB (2 x 2GB)
    SAPPHIRE 100225L Radeon HD 387
    1 x 1tb western digital
    4 x 250 western digital
    2 x 160 western digital
    1 x 320 western digital
amplid
Vlaming
Power User
#11
Yeah scrooge I'm trying to work that out too. Do you also have this icon in your programs menu after downloading flash player:
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
scrooge
Vista Pro
#12
no i can use the 32bit just fine . but a ( 64bit os ) has been out for some time now .i'd
think thay could make one by now . may be it's just not needed or something like that.
i like using the 64bit browser ( why i don't no ) i just do . but the the popup to install flash is getting old .
scrooge
Brink
Staff member
mvp
#13
Amplid,
That would be 32 bit IE7. The 256 bit is just the encryption strength. Both versions of IE7 have 256 bit.
Try using the Adobe uninstaller program in the above post.
This is what it will look like for the 64 bit IE7. Notice the area boxed in red.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
amplid
Vlaming
Power User
#14
Brink, he just won't pull it off. This time I didn't even get the installation movie showing it was installed, just this icon in my programs and features on the CP:
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
amplid
Vlaming
Power User
#15
And there is something in their support section about registry permission issues and SubInAcl. What's that about?
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
#16
Amplid
Hi Amplid,
I believe that that icon is for the flash player uninstall program. I have the same icon in my CP/programs & features, and the player is working fine for me. I did have to go through the Adobe uninstall/reinstall directions a couple times before it took, but got it.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
amplid
Vlaming
Power User
#17
Brink what is all that about permissions and the registry, that roy mentioned as well?
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Brink
Staff member
mvp
#18
Amplid,
I'm not sure what they mean by that. Usually if you have a problem with Flash Player it will need to be uninstalled and reinstalled, or you have DEP enabled in IE7. Check to see if DEP is enabled. If it is, then turn it off in IE7 to see if the Flash player will work afterwards. Option Two in this tutorial will show you how.
http://www.vistax64.com/tutorials/120778-dep-enable-disable.html
As Gary posted, that icon is just the uninstall program for the Adobe Flash Player in Programs & Features. This is normal and should be there.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
amplid
Vlaming
Power User
#19
Hye Brink,
Ah ok, but why don't I get a separate icon for the actual player then? Or is that because it just doesn't install at all? I tried the Disabling for IE7, but when I do this, I can't get on the internet any more:s It doesn't say I have no connection, but simply stays stuck on the 'Connecting...' screen...
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Brink
Staff member
mvp
#20
Amplid,
It will not install a separate shortcut or anything for the flash player. It will just be a add-on for IE7 used automatically when a webpage has any content that uses the Adobe Flash Player.
In IE7, you can click on Tools, Manage Add-ons, Enable or Disable Add-ons to see if the Shockwave Flash Object is installed and enabled.
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
