Need For Speed Most Wanted Won't Install? Here's How!!
Antario
2
I searched Google for two days with every variation of Need for Speed Most Wanted failed installation help I could think of.
I ran the autorun with admin privileges and copied disk one to a hard drive to start the installation but all together and separately failed.
I finally came upon a Linux installation guide on linux-gamers.net that showed exactly how to get it installed.
I tried this on my Vista x64 installation. Just FYI, I also installed the RC1 of SP1 a few days ago too!
For the unabridged version go here: linuX-gamers.net - Howtos - Running "Need for Speed: Most wanted" with Cedega
If you're only getting the directx 9.0c error which halts the installation process at the EULA, you can:
1. Copy disk 1 to a 2nd hdd other than C.
2. Edit autorun.cfg in the autorun folder of the copied contents of disk 1 on your hard drive. You can use notepad to edit the file. The only edits you need to make are:
DirectXVersion=0
StartMenuDXEULA=0
3. Save the file and installation runs without a hitch!
You're welcome!
bsvarma
1
Hi all
I have different problem.
I am using windows xp. I have e installed NFS Most wanted gam successfully. But when i try to play game, got the error like insert DVD or vdc in the drive. If i am trying with DVD also getting same error. Even i tried with daemons tool also same prob. created virtual drive and copied everything and tried. same error. can some one suggest me on this.
please send me your suggestion to [EMAIL REMOVED]. Thanks in advance.
stoneys-nutz
Gamerholic
2,685
Location
Wale's
Hello bsvarma,
If you have a legal copy of the game, try a No CD patch.
Hope this helps, good luck and post your results.
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
