Solved Need Help Please
Katrocks
I have a big problem! Yesterday everything was fine then all of a sudden I could not delete certain files and every time I would open an explorer window another window would open and to finally get to where I want.. I have to open all of these windows very annoying. Also I have never had all the folder options like thumbnail view and so on. Thing is most of this was fine yesterday. I do believe it might have something to do with running CC cleaner because after that all of my setting for explorer were lost. and now I cannot get them back.Then when I tried dragging certain files into other folders I would get a message saying "Target cannot handle this object" I tried in folder options to reset folders also to open folder in same window but nothing. seems Vista is not responding to my requests . I have a UAC tweak installed to minimize vistas requests for confirmation and also had sp1 installed and uninstall ed it but all of this happened before the uninstall of sp1. This started with the cc cleaner so I deleted that don;t trust it anymore seems it has deleted all my vista settings.Also in folder options i do not have the option of viewing thumbnails which is also annoying because I cannot see the photos I want when I want to choose a photo for instance to post on a blog or other.All this is very annoying and the worst of it is that I cannot do a system restore because I have not restore points prior to cc cleaner. shoot what to do? Any suggestions?
Hello Katrocks, and welcome to Vista Forums.
Since it has just happened recently, you might do a System Restore using a restore point dated before the problem to see if it can fix the problem. This tutorial will show you how to if needed.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thankx for the fast reply, but I have resolved all issues, turns out my indexing was out of sinc so I did a re indexing and all is fine now, seems Vista was lost!!
Your welcome Katrocks. Thank you for posting your results back.
