Solved Need Help. Vista Dial-up stuck, Can not dial-up
eynestyne
10
Hey, My notebook has a dial-up problem. Whenever I try to dial-up using any modem, it stops at "Modems Connecting". I thought it was a driver problem until I tried another modem that had always worked.
I did a bit of goggling and found others have had the problem, but I did not find a solution.
Please help!
eynestyne
10
Problem solved. It seems operator assisted dialing was on. I also turned off call back.
If the problem returns i'll post an update.
Hopes this helps someone out there!
