Need help
Generally this problem happens with MS office. Lots of person suffering through this problem, but fixing this problem varries upon computer to computer. So can't say that if a particular system is fixed by one method another would be with the similar solution.
by the way i will ask other expert to see your problem. just have patience and wait.
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
Hello Arvinwebb good advice.
I think you should run a full up-dated virus scan using your security.
I would download and run a full scan using malwarebytes, free version heres the link, so we can rule out those possibilitys.
Malwarebytes
Have you tried to do a sfc scan by using the forum tutorial if not would ask that you do that, I will send you the tutorial.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
If you are able to do this scan, after the scan is done if there are any erros then run the scan 3 mores times as it repairs more each time it is run...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
Hello ,
Just go to the event viewer and open this error and post here a full copy of the error, so we can see what else is there.
To open Event viewer- open Control Panel - then click Administrative Tools - and select Event Viewer from there.
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
Hello ,
1.
Log Name: Application
Source: MsiInstaller
Date: 4/14/2011 8:58:53 AM
Event ID: 11729
Task Category: None
Level: Information
Keywords: Classic
User: SOUSSHERPA\Soussherpa
Computer: Soussherpa
Description:
Product: EZXCocktail -- Configuration failed.
Event Xml:
<Event xmlns="Error">
<System>
<Provider Name="MsiInstaller" />
<EventID Qualifiers="0">11729</EventID>
<Level>4</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2011-04-14T12:58:53.000Z" />
<EventRecordID>86764</EventRecordID>
<Channel>Application</Channel>
<Computer>Soussherpa</Computer>
<Security UserID="S-1-5-21-1529617188-141567142-2727616262-1000" />
</System>
<EventData>
<Data>Product: EZXCocktail -- Configuration failed.</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>
</Data>
<Data>
</Data>
<Binary>7B31343735363746302D383537352D344245302D423542332D3632373036433637464135417D</Binary>
</EventData>
</Event>
2.
Event ID: 1035
Task Category: None
Level: Information
Keywords: Classic
Description:
Windows Installer reconfigured the product. Product Name: EZXCocktail. Product Version: 1.2.4. Product Language: 1033. Reconfiguration success or error status: 1603.
Event Xml:
<System>
<EventID Qualifiers="0">1035</EventID>
<Level>4</Level>
<Task>0</Task>
<EventRecordID>86765</EventRecordID>
</System>
<EventData>
<Data>EZXCocktail</Data>
<Data>1.2.4</Data>
<Data>1033</Data>
<Data>1603</Data>
<Data>(NULL)</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
3.
Date: 4/14/2011 8:58:51 AM
Event ID: 11402
Task Category: None
Level: Error
Keywords: Classic
Description:
Product: EZXCocktail -- Error 1402.Could not open key: UNKNOWN\Components\CFBD0BE63D8C9F4081BCACEAC826851C\0F76574157580EB45B3B2607C676AFA5. System error 5. Verify that you have sufficient access to that key, or contact your support personnel.
Event Xml:
<System>
<EventID Qualifiers="0">11402</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2011-04-14T12:58:51.000Z" />
<EventRecordID>86761</EventRecordID>
</System>
<EventData>
<Data>Product: EZXCocktail -- Error 1402.Could not open key: UNKNOWN\Components\CFBD0BE63D8C9F4081BCACEAC826851C\0F76574157580EB45B3B2607C676AFA5. System error 5. Verify that you have sufficient access to that key, or contact your support personnel.</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
I think these are right.
This software has an authorization code (which I have, I have all the numbers required). I think that what might be at the bottom of this.
