Need link to Vista Home Basic ISO download
bdh516
4
My dad's laptop has crashed, and he needs his OS re-installed. It was Vista home basic (32-bit). He has a valid serial key, and I simply need a link to the ISO download. I've been able to find plenty of ISOs for Windows 7, but those are obviously of no help in this situation. Any help would be greatly appreciated. Cheers!
Ex_Brit
Older but no wiser
2,608
Location
Toronto, Canada
There is no such thing as a legal Windows-anything ISO download. All of them out there are pirated or somehow otherwise illegally obtained. It's also against the EULA to provide such information. Doesn't the laptop come with a recovery partition and some means of using it? You'd have to check with the manufacturer or the shop where it was bought on that score.
Have you tried booting into Safe Mode by tapping F8 repeatedly and selecting that from the ensuing menu? From there you could possibly initiate a System Restore to before the problem started. Don't forget to update immediately afterwards if successful.
    Win 7 Ult SP1 + 2 x Win 10 Pro all x64
Lottiemansion
1,948
Location
Sheffield
Would a Vista Ultimate upgrade back-up disk be ok?
It contains all versions & is selectable on booting!
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Lottiemansion
1,948
Location
Sheffield
For a download of 2.86Gig (32Bit) or 3.66Gig (64Bit) you would need to spend a some time waiting for the download to complete.
Could you not take "the version advice" & "Find a friend" with the correct media?
    40 Meg
Lottiemansion
1,948
Location
Sheffield
#8
OK,
Well, your stuck with obtaining a recovery disk for yourself or waiting untill you "Come across" a correct disk.
    40 Meg
Ex_Brit
Older but no wiser
2,608
Location
Toronto, Canada
#9
As long as you are using your own key there's nothing stopping you using someone else's disk. The Ultimate DVD contains all versions of Vista - it simply installs whatever version is appropriate by reading the key you input early on in the process.
Ex_Brit
Older but no wiser
2,608
Location
Toronto, Canada
#11
It's only the Ultimate version that has them all or to be correct allows that to be done, or so I believe. A Google search might verify that.
Lottiemansion
1,948
Location
Sheffield
#12
Lets talk about the use of a Windows disk for a minute: -
It's like slipstreaming a Service Pack into an existing disk. The disk created is not a Genuine MS produced disk but works as if it was.
So can you get a hold of a disk which has been "Updated" by incorporating a service pack into the image? as per this tutorial: -
http://www.vistax64.com/tutorials/151606-vista-sp1-slipstream-installation-dvd.html
    40 Meg
20
Location
Broken Arrow, OK
#13
If this were true, then why does windows provide windows 7 usb/dvd download tool for .iso downloads? Not only that but .iso downloads are listed as an option at microsoftstore.com
    Dell Inspiron 530s
    Intel Core 2 Dup E4600
    Dell 0RY007
    3GB
    ATI Radeon HD 2400
Ex_Brit
Older but no wiser
2,608
Location
Toronto, Canada
#14
Other software comes in .iso format so that tool has its uses, but if you find Windows online as a download then it has to be illegal unless it's coming from a Microsoft website such as Technet where you would have to be a member anyway.
