Hello everyone, I have been pulling my hair out trying to resolve my issue, and I failed, so here i come looking for some help from those smarter than me.
I have windows Vista Home preimum 32 bit. Know i screwed up, I admiot it, by letting my security suite expire, causing a hacker to find a way into my system. and a good job he did.
now this is a brand new Toshiba laptop, it once had factory restore on a seperate partition but i had to delete it because the hacker compromised it's files.
So here is what I got now, once i found a hacker had compromised my system, i began formatting the hd, erasing it, and then reinstall the operating system. every time i got finished with the installation, it was just l;ike it was before, slow and corrupt. this is what led me to deleting the partition that had the system recovery installed on it.
now I am in Memory by running the MEM at the command prompt, it appears there is all kind of strange files installed here, might also be corrupt. my question is this, how do you uninstall these items from your Memory. I found loadhigh to put them up there but how do you get them out.
I also thought it might be the config.sys or the autoexec.bat but vista don't use these anymore. any help would be appreciated, getting ready to upgrade to windows 7 and need to get this memory issue resolved
thanks
thanks
