Need to change keyboard shortcuts
Wowmanwow
Hey Hey, can anyone tell me if its possible to change the generic Vista keyboards shortcuts?
I'm having problems playing games (WOW in particular) where I hit Alt F4 or Alt TAB and it takes me out of the game, quite frustrating! I know it will most likely be easier to change in game setup but im hoping to be able to disable the Vista shortcuts or at least disable them for this program etc
Thanks Heaps!
Frostmourne
Banned
Change it in Warcraft. Just remap the Alt, and any other keys.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Wowmanwow
Thanks for the quick responses, Lemur - Have you used Hotkey? Will I be able to use this to ensure that if I hit ALT - F4 nothing will happen? Or if I rekey the ALT F4 command to another set of keys, the original ALT F4 will still function, as that won't help me :)
Frostmourne (wow server?), thanks for the suggestion but I need to change the Vista setting as Im too used to my in game key setup :) (arena healer, so ALT does it all for me)
