Solved .Net framework problem
dglawton
Greetings. Windows Media Center will not start. The error states that there is no .Net Framework install root in the registry. Both 3.5 SP2 and 4.0 were installed at the time. Per forum recommendations, I removed and re-installed both. Error still occurs. I purchased and ran registry booster; it found and fixed a bunch of problems. Error still occurs. Any ideas? Thanks.
-Don Lawton
Hello dglawton and welcome to the forums :party:
Can you follow these steps for me please?
1. Open the start menu
2. In the search box, type cmd
3. Right click on command prompt and select run as administrator
4. In command prompt, type:
sfc /scannow
Let it run, it should take about 10-15 minutes. This will check the integrity of your system files and will attempt to replace or repair corrupted or missing files.
Repeat this process 3 times (sometimes it isn't fixed on the first time), and if it is still detecting problems ("Integrity Violations"), then let me know and we will try something else.
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Thanks for your quick reply Tom.
I ran the recommended app three times re-booting between each. Each ran to completion with the following output
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>sfc/scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
When starting WMC I still get a message box titled
ehshell.exe - .Net Framework Initialization Error
with the message
Please set the registry key HKLM\Software\Microsoft\.Netframework\InstallRoot to point to the .NET Framework install location
There are plenty of keys in HKEY_LOCAL_MACHINE\Software\Microsoft\.NETFramework but no Installroot.
Thanks again for the procedure. Any other ideas?
-Don
Can you download and install CCleaner:
CCleaner - Optimization and Cleaning - Free Download
Run the cleaner, and the registry cleaner
BACK UP THE REGISTRY WHEN PROMPTED
Then reboot, and let me know if this has any effect.
Also, do you have the latest updates installed?
And how recent is this problem?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
-Don Lawton
Hello Don,
According the .NET Expert Aaron Stebner if .NET is corrupted the only way to fix it is to run a Repair to your OS. How to repair the .NET Framework 2.0 and 3.0 on Windows Vista - Aaron Stebner's WebLog - Site Home - MSDN Blogs follow this article to run a Repair http://www.vistax64.com/tutorials/88236-repair-install-vista.html
Captain
Re: .Net framework problem - solved
Thanks for all the help.. I solved the problem by upgrading to Windows 7 Ultimate.. drastic but effective.
Glad to hear the problem has been fixed :) But I apologise that I wasn't able to help you more
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
