Solved no connection to WiFi
brunffery
I need help with this. All laptops, cell phones and tablets can connect to My WiFi/router except the desktop.
The second and third attachment shows the results from the diagnosis which all didn't work.
I then did the "cmd" in the run field in order to release and renew dns but to no avail. That's the first attachment you see.
Any suggestions?
erpster4
where are the "attachments"? I don't see them posted in your thread.
and what kind of "desktop" computer are you using that has the wifi connection problem?
you may need to install a stronger usb wireless lan adapter so that it can find your wifi/router
    Windows 7 SP1 Ultimate x64
    4Gb (3.24Gb usable to OS)
    Sigmatel/IDT STAC9200
brunffery
I'm not sure what happen to the attachments but we had a technician come to the home and he gave us a new router. This actually helped the connection. He did some other work on the Computer which revealed that we were not in the correct network to pick up our home wifi. We were connected elsewhere. Thank you for your reply and help!
