no network after normal boot
raiderman06
Recently my laptop will not connect wirelessly after boot. I can boot in safemode with networking and will connect fine. Some of my applications can connect through their ports after normal boot. Seems to affect everything using "Connect to" from start menu. Also after normal boot clicking "Connect to" or trying to open networking/connections causes freeze up. Any suggestions? Thanks.
Raiderman06
    gateway p7811fx
    4gb
    nvidia
Retirednow
Power User
In normal mode, open Device manager and see if there are any red x's or yellow flags next to the network adapter. Next, again in normal mode, open a command prompt and type the following without the quotes and paste all the results back here, "ipconfig /all". If you connect to the router with an ethernet cable and boot to normal mode, can you get on the Internet?
raiderman06
When booted in normal mode - clicking on device manager, network/sharing or programs features will open the frame (with nothing in it) and then program locks up - that is to say icon shows work and and nothing happening - task manager can end program but with message "not responding" - I can go to dos prompt and ping router / other servers and applications with their own port settings connect just fine - just seems to be ie and above mentioned problems. I can boot in safe mode w/ networking and connection works - device manager in safe mode does not show any problems for what thats worth - Connecting with cable has same effect - no ie and no use of network/sharing file. I have tried booting to dos prompt and restoring to prior date but that has not fixed issue. I have checked for malware and none is indicated. will run ipconfig and repost - ty for reply.
    gateway p7811fx
    4gb
    nvidia
raiderman06
Windows IP Configuration
Host Name . . . . . . . . . . . . : carverfamily-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Wireless WiFi Link 5100
Physical Address. . . . . . . . . : 00-16-EA-72-7D-D8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::79d7:fca1:e183:ff3b%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.67(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, July 16, 2010 9:18:46 PM
Lease Expires . . . . . . . . . . : Saturday, July 17, 2010 9:18:46 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 268441322
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0F-FF-13-75-00-1D-72-3C-C3-5B
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Marvell Yukon 88E8057 PCI-E Gigabit Ether
net Controller
Physical Address. . . . . . . . . : 00-1D-72-3F-73-F6
here is the ipconfig/all results
    gateway p7811fx
    4gb
    nvidia
ilikefree
I would uninstall your wireless driver and reboot then reinstall the driver again with another reboot.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
