Solved No sound after installing audio drivers
Hexagon12
I can't get sound working in Windows Vista. However, the sound drivers are installed. Sound was working in Windows XP and 7. Sound is not muted.
    ASUS
    Intel Core [email protected]
    H110M-A D3
    6 GB DDR3
    NVidia GeForce GTX 750 Ti
    Desperatly searching for a Windows Vista HomePremium x64 iso for a virtual machine!
Hexagon12
Bump????
    ASUS
    H110M-A D3
    6 GB DDR3
M
mdiemer
Go to Control Panel/Hardware and Sound/Sound/Manage audio Devices. Make sure your audio device is selected as the default under <playback> and <record.>
Hexagon12
I already did that. What to do now?
    ASUS
    Intel Core i3-[email protected]
    H110M-A D3
    6 GB DDR3
M
mdiemer
What kind of sound do you have? Onboard, or a sound card? If you have a sound card, you may need to disable the onboard audio. I'm assuming you have the speakers hooked-up correctly, but it never hurts to check all the wires, make sure you don't have the mute button on; etc.
Hexagon12
I have integrated sound. This means that the sound is coming from computer speakers.
    ASUS
    H110M-A D3
    6 GB DDR3
M
mdiemer
Have tried uninstalling and reinstalling the drivers? Maybe you need to contact SoundMAX support.
A possible fix would be to use ASIO4ALL drivers. They are free, safe and work well.
Hexagon12
Can you give a link to these drivers? Also tried uninstalling and installing again from windows update.
    ASUS
    H110M-A D3
    6 GB DDR3
Hexagon12
I tried the ASIO4ALL drivers, nothing happened. The sound drivers aren't showing anymore. Is there an update to my onboard sound? It's SoundMAX integrated digital audio.
    ASUS
    H110M-A D3
    6 GB DDR3
M
mdiemer
You could get a cheap sound card. That should solve the problem. Sorry I have no other suggestions. Anyone else have any ideas here?
Lottiemansion
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Hexagon12
THANKS!!!
The drivers you listed are working fine.
Marking thread as solved.
    ASUS
    H110M-A D3
    6 GB DDR3
