Hi, i recently had a blue screen of death and i wasn't able to read the error message from the screen. When i restarted my computer my sound just died. All the drivers are working and nothing is muted. I tried disabling and enabling my Realtek Sound driver from Device Manager and i also uninstalled and reinstalled the driver but it didn't work. I Checked my Windows Audio Service and disabled and enabled it but that didn't work either. If i try to plug in a microphone or a headset into my computer it does not pick it up. I really don't know what is wrong as my the drivers are listed as working properly but there is no sound coming from my speakers or a headset that i plug in. Here are my specs.
Time of this report: 8/16/2012, 16:04:56
Operating System: Windows Vista™ Home Premium (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.080425-1930)
Language: English (Regional Setting: English)
System Manufacturer: Alienware
System Model: m15x
BIOS: PhoenixBIOS 4.0 Release 6.1
Processor: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 2046MB RAM
Page File: 1930MB used, 2410MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6001.18000 64bit Unicode
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0885&SUBSYS_152D0770&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6662 (English)
Driver Attributes: Final Retail
WHQL Logo'd: Yes
Date and Size: 6/19/2012 16:54:20, 4065296 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Digital Mic (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Stereo Mix (Realtek High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
System Model: m15x
Memory: 2046MB RAM
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Cap Flags: 0x1
Cap Flags: 0x1
DxDiag Notes
