Solved NOD32 Won't Update!
Smurfyy
Danny :)
Hey everyone! :D
Yesterday a NOD32 notification popped up telling me that it needed updating, so i clicked it and clicked the update button.
It looked like it was updating so i left it and when it finished i shut down the pc.
This morning ive turned it on and it still says that it needs to be updated.
Now ive just looked and it says the last sucesfull update was 31/12/2005 23:06:48. When i moved my computer over to the new case everything on the BIOS reset itself.
Could this be the problem?
If it is, how do i remove the last update so i can install one that is this date?
Thanks in advanced!
Daniel ;)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    1 128GB Kingston SSD Now OS drive
    1 250GB sata main drive.
    1 160GB from old install.
    1 500GB for re-directs from OS disk.
    1 Seagate GoFlex External 1TB with backups.
    750 watt.
    Foxconn TSAA699.
    4 fans.
    ASUS EEEPad Transformer 16GB with Dock w/32GB class10 SD |
    Dell PE1950 II / 2xDual Core Xeons @3.00GHz / 16GB RAM / PERC 5i/R / 2x36GB SAS OS - 2x1TB SATA Data both RAID 1 |
SOLVED!
The date was still wrong, so changed it and left it to update and its all sorted now :D
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Go to Advanced mode,log files, in the drop down box, change it from detected threats to Events. Your updates are there.
EDIT:Too Late
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
