Normal temp of a GPU?
RetroDude
Depends on the graphics card, what are u running.
    AMD AM2 Athlon 64 X2 6000+
    MSI K9A2 Platinum
    2GB (2x1GB) Matched Corsair DDR2 Memory 800
    Sapphire Radeon 4870 512MB
    On Board (Upgrade soon)
    17" :Hansol CRT Monitor
    1024x768
    500GB Western Digital Caviar 7200rpm
    Corsair TX750W
    Antec 900
    3x120mm Case fans, 1x200mm Exhaust Fan, Stock CPU Cooler
    Genius Netscroll+Eye Ruby
    IBM KB-9910
    Up to 16mb usually around 6-8MB
    CPU Temp at almost full load was around 36oC, Graphics Card rarely goes above 58oC
xeon1203
Ohh! It's cool. I thought normal temp of your VGA at 70+ celsius
I don't know Temperature of your country Because I live in Thailand.
    No name
    Pentium D 915
    P5KR
    Kington 1GB/800 *4
    EN8500GT 256MB DDR2
    On Board
    HP mx705
    None
    Seagate 160GB S-ATA II
    WD Western Digital 160GB S-ATA II
    No Name
    No Name
    No Name
    y TECH
    Acer
    2 Mbps/512 Kbps
Blaydrnnnr
Completely Lost
Yep, if your running Warhammer at 60..your fine. Cooler is better.. but thats well in range of good temps. The way air moves in your case can affect your temps and even the air temp in the room... so there are ways to get cooler.. but I wouldnt sweat it. ( sorrry..bad joke..) your temps are fine.
    Q9550 2.83 Quad
    8 GB OCZ 800MHz
    Nvidia 9800 GT 1GB
    LG 24
    2 500 GB 32MB Seagate( Raid 0 )
    1 1000 GB 32MB Seagate
    PC P{ower and Cooler 1000W
    HP d5000t ATX CTO
