Norton 2009
maebee90
16
I downloaded the trial version..and and trial reset and your suppose to turn off the product tamper protection but it not in the miscellaneous options...how do i find it? Why is it hidden?
Crispy2007
64 |3!T G33|<
160
Location
Aus, QLD
Best advice anyone can ever give you about Norton is UNINSTALL it, its a resource hog.
    Intel Core 2 Quad Q6600 (G0 Kentsfield) LGA775 (FC-LGA6)
    GIGABYTE GA-EP35C-DS3R (Rev. 2.1)
    Corsair TW3X4G1333C9A 4GB PC-10600 (2x XMS3 2GB)
    ASUS nVIDIA GeForce 8800 GT (G92GT/D8P)
    Creative SoundBlaster Audigy 2 ZS/RealTek ALC885/889A/890
    ChiMei CMV CT-730D 17inch (LCD Monitor)
    1280-1024 60Hertz (Ture Colour 32bit)
    Barracuda 7200.10 SATA 3.0Gb/s 160-GB Hard Drive ST3160815AS (RAID0)
    SUPER FLOWER 500watt Plug in Leads 24pin ATX BLACK MODEL
    Thermaltake Shark (VA7000SWA ATX) Full Tower
    Front 120mm fan (1400 RPM) /Rear 120mm (1400 RPM) blue LED
    Cyber Snipa Stinger Laser Gameing Mouse (400-3200Dpi)
    Labtec Media Desktop Y-SAD65
    Telstra BigPond Elite Liberty Cable 17Mbps/256kbps
Crispy2007
64 |3!T G33|<
160
Location
Aus, QLD
Norton will slow your computer down is a crap anti-virus.
Crispy2007
64 |3!T G33|<
160
Location
Aus, QLD
For the average user I would recommend AVG, but if you want something more advanced use Zone Alarm.
24
I like Avast myself. Also:
Use at least two anti-spyware solutions like Ad-Aware and Malwarebytes
Run as a standard user
Have a firewall on your router and your PC
Don't download/install/click things unless you trust the source
    Gateway GT5662
    AMD Phenom 9500+
    ECS
    3GB
    8800GT 512
    Onboard Realtek HD Audio
    22" Apple Cinema Display
    1920x1200
    Dual 160GB HD's in RAID-0
    600W
    10Mbps
archie123
I Tunes hates Me
1,831
Location
UK
#8
no its not , norton always has and always will be one of the best antivirus solutions around , they have been doing it a very long time and they are very good at it , and its not a resource hog , it never was , as a standalone Norton AV is one of the best.
It got a bad name (and rightly so) for its internet security suites (firwall/antivirus/antispyware) and i was one of its big haters , i still am , they werer a resource hog , even though they have made massive improvements with norton 360 they still try too hard to make it idiot proof and do everything for you giving you very little control over anything. But all that said i installed 360 on our work PC as it came free and i was pleasently surprised. (i still wouldnt touch it with a bargepole)
BUT the AV alone is very good
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Submarine
Vista Pro
394
Location
Stockholm, Sweden
#10
Northon is a good AW program and the latest version is light. Can be recommended.
    Dell XPS720
    Intel Quad Q6600 2.40GHz
    4GB DDR2 800MHz
    Creative SB X-Fi Xtreme Gamer
    Dell 2407WFP-HC
    1920x1200
    NVIDIA 640GB SATA Raid 0 (2x320GB) (7200 rpm) for Vista,
    Intel X25-M G2 160 GB for W7,
    Maxtor OT III External HDD,
    WD Elements 1 TB External HDD
dinesh
Vista Expert
1,333
Location
India
#11
You are not supposed to discuss cracks and trial resets in the Forums.
However, you can PM to any member to do so. ;)
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
dinesh
Vista Expert
1,333
Location
India
#13
can anyone answer my first question tho?
It should be listed in the Misc settings option. Try reinstalling Norton and you may find the option. Or just go thru all the settings and you should find it.
    Compaq
    15"
    160 GB WDC
JMH
Banned
2,141
#15
Have you contacted Norton support about this? It may only be a trial version but you may also be a potential paying customer. ;)
    IntelCore 2DuoT8300@2.4GHz x2
    1440 x 900
    SPECS.
    Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device
    Drive 2. [ All as above.]
    CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
dinesh
Vista Expert
1,333
Location
India
#16
Why don't you try free AV from MS- Morro?
    Compaq
    15"
    160 GB WDC
archie123
I Tunes hates Me
1,831
Location
UK
#17
[FONT=book antiqua,palatino]Open Norton product> Click Norton Internet Security/Norton Antivirus tab.> Under Settings, click Norton Internet Security/Norton Antivirus Option at the bottom> In the new window, under General Options> Settings> Under How to protect your product from Hackers, you can see Turn on protection for your Norton product (Recommended).[/FONT]​
i assume you turn it off there
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
maebee90
16
#18
Umm didnt find anyof those tabs
kavita
CCNA
Vista Pro
276
Location
India
#19
Are you using Norton AV or norton Internet security 09? which version are you using? If you just wanna use trial reset then download the latest version of NIS 09 from www.symantec.com and then you will surely find what you are looking for.
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
30
Location
Dallas, Texas
#20
NIS 2009 does not slow your computer at all. It's a lot better than previous Norton IS and I was running 2GB of ram with it on Vista and 1GB of ram on XP. No performance hit at all. Only using 3.5MB of ram on my computer. The uninstaller on 2009 is miles better than it is on the older version.
Just another user that base his opinion on past products. :rolleyes: Who uses Zone Alarm???
    Shuttle SN68SG2
    AMD Athlon X2 4400+
    Corsair XMS 4GB DDR2-6400
    BFG Nvidia GeForce 9600GT
    stock
    LG W1952TQ
    320GB SATA Western Digital
    80GB PATA Samsung Drive
    stock
    Logitech G5 Laser Mouse
    Logitech standard keyboard
