Not Installed ACPI\AWY0001
stasioau
V64,In Device Manager, under "other devices" see "unknow device" ACPI\AWY0001 as not installed (Code28).
Does anybody can help me what it is?
jackthejerk
MSI -- MICRO-STAR INT'L CO., LTD.
is the driver needed,, I have had the exact same problem,, don't worry if you do not have an msi motherboard it will work on any board with that string,, I have used it on msi, asus, and abit so far ,and it fixes it every time
johngalt
Antidisestablishmentarianist
Assuming, of course, that he has an MSI motherboard....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
jackthejerk
it has worked on all motherboards I have tested so far that was having the problem,, asus abit and msi so far. its not a driver for the motherboard it is for an amd chip function. that is just the place I have been downloading it from,, again it doesn't matter that it is from the msi website
johngalt
OK, then a bit more explanation would be helpful - more than half of the people who have non MSI motherboards would think the same thing.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
roy69
47,65,65,6B
This error also relates to intel quick resume technology, we need to see the system specs before posting any links for a fix.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Toropop
Geek w/Social Skills
Thank you, jackthejerk. Your suggestion helped me out of a similar situation I was experiencing on an ASUS M2N32-SLI Deluxe board under Windows Vista Ultimate SP1 64-bit.
    AMD Athlon FX-62
    4GB Corsair XMS2
    2x GeForce 8600GTS in SLI Mode
roy69
47,65,65,6B
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
marcnz
I have a Dell Dimension 9200 and got same problem with the installed Windows XP Pro. This link has fixed it and it is all good in the device manager now.
Amazing to find out that AMD is fixing Intel/Dell mess up!
Thanks for the link.
Crooze
This worked for me on my ASUS M2N-E running Vista Ultimate SP1 64-bit
Thanks!
    AMD64 X2 5000
    ASUS MN2E
    4GB Corsair
    nVidia 8600 GT 256
    2X 320 Gb WD
Deputy Dawg0
I just tried the link and it resolved the problem. I have an Intel DG965WH motherboard. I could not find any driver that would work. The link that JacktheJerk posted fixed it right away. It moved the device under System Devices. It is about the fourth one listed as "AMD AwayMode".
Thanks Jack
Deputy Dawg0
Stirbello
Your answer helped me out of a similar situation
This worked for a MS-7502 Board under Windows Vista Home Premium SP1 64-bit.
THX from Germany
JAG
Hi, I have just encountered the yellow ! under "Others" as shown within the Device Manager for my Dell Inspiron 531; an AMD Athlon PC with 64 x 2 Dual Core Processor @ 2.31 GHz.
Checking under properties I too had the ACPI\AWY0001 missing driver problem after doing a clean install moving from Vista 32bit OS to Windows 7 64bit OS.
I followed the link to MSi and downloaded the Vista_AMDAWAY .zip file containing setup.exe (filesize of 1,835KB.) Although the package will say it is not compatible it will run if you supply permission and try a second time. Having loaded the driver it appears to have solved my missing driver problem.
Please remember that making changes such as these do have a risk - so please proceed carefully making sure you know what to do should you need to recover or revert the change.
Ddesbiens
Ok all, i have registred new account on this forum just to thank you for this thread and the link (the updated link was good).
Just a strange thing that is an AMD driver that solve an unknown device problem on an Intel motherboard!!
It work on Windows 7 64 Bits (just run as Windows vista compatibility for working).
Many many thanks, i spent some 2 hours to find the problem and i found you!!!
Thinkpositiv
Hello,
I had the same problem as described above on an Asus M2A-VM HDMI Board with Windows 7 Home Premium 64bit.
I extracted the Vista_AMDAWAY.zip (it contains setup.exe and AmdAway.zip) and run the setup.exe. That did not work for me, as it detected I'm not running Win2000, XP or 2003.
I extracted the AmdAway.zip and Readme/ReadMe.rtf in it contains detailed install instructions. In short:
- on the problematic device choose rightclick > update drivers
- choose on local PC
- browse to the folder where you unzipped AmdAway.zip (where AmdAway.inf resides)
- hit OK/Next
(Free translation from German, exact English terms may vary ;) )
That installed it as "AMD AwayMode" device.
hope that helps,
Thinkpositiv
kiwivda
Works great for me to on my system Asus M2n32-sli. A new mirror here. Just installed the program and the device becomed:
Field Value
Device Properties
Driver Description AMD AwayMode
Driver Date 06/04/2006
Driver Version 1.0.1.0
Driver Provider AMD
INF File oem40.inf
Hardware ID ACPI\AWY0001
PnP Device Intel Quick Resume Technology
    QuadCore AMD Phenom II X4 Black Edition 940
    Asus M2N32-SLI Deluxe
    8192 MB (DDR2-800 DDR2 SDRAM)
    NVIDIA GeForce 8800 GTS SLI GTX 295
    nVIDIA nForce 590 SLI (MCP55PXE) - High Definition Audio
    Samsung SyncMaster 206BW/MagicSyncMaster CX206BW (Digital) [20" LCD] (HSGP302242)
    Disk Drive WDC WD10 02FAEX-00Z3A SCSI Disk Device (931 GB)
    Disk Drive WDC WD15 00HLFS-01G6U SCSI Disk Device (139 GB)
    Optica
    Seasonic S12-650 Energy Plus Series 80
    Cooler Master Sileo 500
    Noctua
