Fiery
Gday
I purchased a Samsung SSD 840 Pro, prior to installation I set the BIOS to AHCI. Put the SSD in and migrated my OS onto the new HD.
It wasn't until after a few boot ups, I noticed it was skipping the boot order of CD/DVD then HD. I double checked the BIOS to make sure this was indeed the correct boot order, it was.
I needed to boot off my Vista Disk, however, because it was skipping the boot order it didn't boot from the Disk.
The only way I could think of to get my boot order back, was to switch the BIOS back to IDE. Rebooted and it read the Disk.
What I would like, is to KEEP MY BOOT ORDER CD/DVD then HD.
Motherboard is a Gigabyte GA-MA770T-UD3P.
Any suggestions?
I contacted Gigabyte this was there response :-
Dear Susan,
Thank you for your kindly mail and inquiry. About the issue you mentioned, please change the battery and the model of the battery is CR2032. You can use any manufacturer for the bettery, but make sure the bettery model is CR2032 for 3V. After you change the battery, you may check if BIOS could work properly.
Regards,
GIGABYTE
N.B THE BIOS COULD WORK NOT WILL WORK!
Any suggestions?
Dear Susan,
Regards,
GIGABYTE
- Homebuilt
- AMD Phenom II x 4 965
- Gigabyte GA-MA770T-UD3P
- 4GB DDR3
- Graphics Card(s)
- Nvidia GeForce GTX 750 TI
- Creative Sound Blaster X-Fi Xtreme Audio
- Phillips 19"
- 1280 x 1024
- 1 x 128GB Samsung 840 Pro SSD
1 x 1TB Sata
1 x 160GB IDE
1 x 2Tb WD External My Book Elite
1 x 1TB WD External My Book Elite
1 x 4TB WD External My Book
- PSU
- Thermaltake 850W XT
- Case
- Coolermaster Storm Sniper Black Edition
- Cooling
- AC-ALPINE-64PRO ARTIC COOLING
- 12 year old Compaq, cant see any of the letters anymore :)
- Microflacid Sterile
- ADSL2+
- Other Info
- My husband and I divorced over religious differences.. He thought he was God and I didn't.
