Nvidia GEForce Experience
Fiery
Okay I have a question, I reluctantly upgraded my Nvidia Silent Cell 9500GT (only reluctant because it is silent), to a GeForce 760 TI, not the fastest on the block, but I am not into high end gaming. The only game I have on my PC is Warcraft 3 The Frozen Throne NOT WoW.
My question is two fold, one the last few Experience updates, will simply not work, I contacted Nvidia Tech Support, they had me uninstall everything to do with the GPU and reinstall it. No go. It was then suggested I do an OS reinstall, naturally there were no guarantees that would work.
So I did a dual boot, my main OS is Vista, I also have Win7 Ultimate, which I installed, did the GPU Updates same error (it just wouldn't work).
Re contacted Nvidia, they said to RMA it, it was faulty. (I have yet to take it out of my case).
Now the second part of my question is, does the GeForce Experience make any impact on the "gaming experience"?
As I said I only play Warcraft 3 The Frozen Throne and I haven't noticed any change.
Here in lays my dilemma, there is another PC in the house, but the case is to small to take my GPU, I have a work around for the "Experience", I install the latest drivers and have a stand alone version of the GEForce Experience V1.7 which works!
Do I take the card out and RMA it or keep the card?
    Homebuilt
    AMD Phenom II x 4 965
    Gigabyte GA-MA770T-UD3P
    4GB DDR3
    Nvidia GeForce GTX 750 TI
    Creative Sound Blaster X-Fi Xtreme Audio
    Phillips 19"
    1280 x 1024
    1 x 128GB Samsung 840 Pro SSD
    1 x 1TB Sata
    1 x 160GB IDE
    1 x 2Tb WD External My Book Elite
    1 x 1TB WD External My Book Elite
    1 x 4TB WD External My Book
    Thermaltake 850W XT
    Coolermaster Storm Sniper Black Edition
    AC-ALPINE-64PRO ARTIC COOLING
    12 year old Compaq, cant see any of the letters anymore :)
    Microflacid Sterile
    ADSL2+
    My husband and I divorced over religious differences.. He thought he was God and I didn't.
Well you are the only one to answer that question: -
Your card is damaged but will work if it is driver down graded. However, you bought a good card & can not use it at it's best. So, I would rip it out & get them to replace it.
Ask them to send the replacement first, if they are that sure it needs replacing!
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
That's interesting. I have a 560 Ti that works properly and has done so for the last 2 years. I also find that the GForce Experience will show the installed driver but doesn't find the latest driver. I think it worked correctly initially. I didn't have the GForce Experience until I installed the 343.xx driver. I then rolled back that driver because it doesn't support CUDA acceleration for my card. I believe that's when it quit working to find the latest driver.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
