NVIDIA SDk 11
23
Location
Dublin Ireland
Has anybody ever dabbled with Nivida SDK (software development kits) for DirectX.
What do they do and are they risky to dabble with?
DirectX | NVIDIA Developer Zone
Every time I try and install my favorite classic games, I get some form of DirectDraw or Direct 3D issue!
These games are not very graphics intensive and some of them date back to DirectX 7!!!
The bottom line is that Nvidia will not allow me to change any of the display settings and thus hardware acceleration is something I can not access! :(
    Del XPS M1330
    Intel Core 2 Duo T5900 2.2 GHz
    NVIDIA GEFORCE 8400M GS
    N/A
    N/A
    N/A
    8 x DVD R/W
    1 X SD/MMC
    2 X USB 2.0
    1 X HDMI OUT
    1 X 1394 PORT
    1 X VGA
    Fingerswipe access
    Mini remote control
    Trayless optical drive
Patonb
2,245
SDK are not really meant to help the end user, they are more for developers making stuff.
The problem you have is the games probably are not playuing well with direct X. I've had a game do that and search showed some internal tweek on a config file solved it.
You should jusst google the game and error code to solve them.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
23
Location
Dublin Ireland
Thanks patnob
Thats what i needed to know regarding the sdk.
As regards the game config, youre right, but which file and where can i get the fix-it code. I know the answer is out there somewhere but i just dont know where to start since this i so over my head!
    Del XPS M1330
    N/A
    N/A
    N/A
    8 x DVD R/W
    1 X SD/MMC
    2 X USB 2.0
    1 X HDMI OUT
    1 X 1394 PORT
    1 X VGA
    Fingerswipe access
    Mini remote control
Patonb
2,245
I'd start by googling the game name and the error number or sentence.
Usally its on a foftum exactly how to fix it
