Hey guys Great site and its helped me loads before, I'm sorry my first post is a question but this seamed the best place to ask for reassurance.
Im upgrading my rig before going to university and finally wanted to take the leap from 32 bit windows to 64 bit. I have decided for various reasons to stick with windows vista over moving to 7 or waiting for 8. I have i identified several options available to me, the main limiting factor being availability however i have a few questions regarding them. Either i purchase an 64bit OEM copy of home premium or I purchase a Vista Ultimate upgrade edition (with both 32 and 64 bit disks).
I know how the OEM version will work (it is effectively the 64 bit version of what i am using now and have experience with) But i am a bit rusty as to how the Upgrade Disks work.
Is it possible, using an upgrade disk, to upgrade from windows vista 32 bit Home Premium to 64 bit Ultimate?
I have heard rumors that the "OEM system builders" cd keys can be used to install 64 bit or 32 bit versions of the software without issue assuming the corresponding 64 or 32 bit disk is used. I this true?
(This is more for reference as i intend to put the old board and cpu to good use in the near future. The system upgrade of my main machine is going to be so substantial that im practically building a new pc which would breach the terms of use.)
Can you tell me any other pros or cons i will face by using the OEM version or and upgrade version?
Thanks
-Revodb
Thanks
-Revodb
- Intel CORE 2 DUO
- MSI G41-P28
- 3GB
