Office application version does not match.
jtfirelm
Whenever I open an office program a message appears stating that the "Office application version does not match." When I press okay it goes away and everything seems to run normally. I have looked on the Mircosoft and it sees it is something to do with outlook. i do not have outlook on my pc any more as it ran out of trails.(I am running the student version). Just wondering how to get rid of it.
Thanks Jack
richc46
Remnants of Outlook remain
Try downloading ccleaner and running. See if that helps
richc46
That is the job of Ccleaner to remove crap that is left over. When you use check all the items that you feel comfortable with. If it does not work, tell me what you checked and maybe we can add a few more.
Shadowjk
Network Enthusiast
Thanks for the help.
How do i use ccleaner to remove outlooks remaining items?
In this case and this case ONLY Run a registry Scan to see if any Outlook Registry Keys still remain
Registry Scans can be Dangerous to your Computer yet can be useful, Vista Forums are not Responsible for any Damdge caused to your Computer due to Improper use of Registry Cleaners
After you have run the Scan Repair any Registry Keys and then Report back
Ccleaner is usually a Safe Registry Cleaner but Please be aware of the consequences
Many Thanks,
Josh ;)
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW ([email protected])
    Novatech Night
    Dell HID-compliant mouse
jtfirelm
Thanks again.
Okay so an unused file extension( .nds) popped up and unused registry key(.exe\OpenWithList) as well.
Are these anything to do with outlook.
