Ok to delete ntuser.dat.LOG1?
5
i want to know if what that file
ntuser.dat.LOG1 256kb
ntuser.dat.LOG2 0 kb
if i delete it there is any problem in that ? and in the same time dont to delete because it said that ues by other program....
richc46
Staff member
20,105
Location
Fairfield County, CT
Re: hi i want to ask
Welcome, run your antivirus and then download and use this:
Malwarebytes.org
If both tests are negative and it is not a virus, the best course of action is to leave it alone unless you are sure of what it is.
I did look it up for you and this is what I found out:
What is ntuser.dat.LOG1 file under Users>default
