Old computer really slow...
235
Location
Oklahoma, USA
ok my old comp is a p4 HT w/ vista x86..
for a couple of days i've been noticing that everythin takes forever to load, when it used to be as fast as....my new comp is still doin great, and they have the exact same programs and all except the new one is x64...on the performance monitor it says 80% memory being used, and my new one about 43%...the old one also shows 380 Hardfaults/min on there and my new one only showing 0 or 1...this is really laggin up things...its svchost..any idea..cuz this is pretty much everythin..but still, my new comp is barely using any resources on this
help would be appreciated
thanks
new comp pic on top
old comp is on bottom..
old one is really slow and maybe screwed up
ripbox
Nerd
Vista Pro
591
and my new one about 43%.....wow that is realy high. ihave the same prosseccer as you and i idle at 1%
must be somthing you have installed... but dont forget defrag and defender allways run when your pc's idle so the % is never true untill you disable them 2 progs
as for your ram yes vista is like a rasta after huge smoking session :P
it realy does get the munchies i have 4gb and currently using 37%
but again dont forgrt its what you have running/installed that make this
try to take into account ur anti virus firewall ect
i suggest getting a core gadget for your pc's so you can moniter when ur cpu load is high i hade a very similare problem with a host and was able to pin down that ventilo (v.o.i.p)wast killing core 1
i hope you find your fault
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
