overclocking graphics card question!
146
Location
England
When someone says they have the graphics card clocked at something good for the sake of the argument say there original core clock was 600 mhz then they got it to 700mhz stable. Would everyone who had the same card be able to get it stable at 700mhz (for the sake of the argument) or are there variables which depend how high or low u can get the clock!? thanks ill explain again if u dont understand!
    Intel Pentium Dual Core E5200 Overclocked @ 2.90
    ASUStek
    OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
    ASUStek ENGTX275 PCI-E x 1
    19inch benq
    1400x900
    400 gb
    700 Watt artic power
    Artic cooler
    4.70 mb/s download, 0.37 mb/s upload
um i think there are variables on it.... one reason ATI is better gpu you get higher overclocks ;) like the 4890 can get is core to over 1ghz
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    500gb Seagate SATA II
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    AVerMedia 1500MCE TV Tuner
archie123
I Tunes hates Me
1,831
Location
UK
it varies from card to card even the same card from the same vendor can vary in how they oc , certain manufacturers will "cherry pick" cores and fit high quality ram to their boards as well as high quality capacitors etc and they up the voltage in the cards bios and fit better cooling , these are usually the factory overclocked models which you pay a premium for , overclocking these any further is usually difficult , sometimes if your very lucky you may end up with a cheap "base" model gpu that clocks very well but as they usually have cheaper lower quality components / ram they are also hard to get a decent oc on without a volt mod
generly speaking unless you can get get a good oc on the cards ram (higher bandwidth) its not worth overclocking its alot of hard work for 2 or 3 fps , people normaly oc for higher benchmark scores , ingame the differance is usually very small
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
146
Location
England
Thanks all :)
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
smarteyeball
Eye know, eye know
1,874
Location
Australia
+1
It also adds to the temps which forces you to run the fan speed higher (if set manually)
As Archie says, it's luck of the draw as to how well you can overclock a card.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
146
Location
England
Its just arrived my gtx 275 asus :) Gonna install it now!
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
146
Location
England
Asus ENGTX275 Review - Page 3 - Box, bundle and overclocking
This is how far they got theyre overclock (they say they could have squeesed more tho)
will i be able to put it straight at those clocks?
734 / 1628 / 1282
Note: This is exactly the same graphics card i will install in 3 hours or so! (Its arrived)
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
#8
maybe maybe not.... all depends..... still think you should have found a 5850 though ;)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
archie123
I Tunes hates Me
1,831
Location
UK
#9
734 / 1628 / 1282
your running at 1440x900 that card will eat anything you throw at it for breakfast at that resolution , dont overclock the card mate its not worth it , when you get a new monitor and a bit more time we can go into the ins and outs of overclocking properly , benchmarking properly and using apps like riva tuner to set up custom fan profiles so your card doesnt get too hot , at the moment its not worthe the work ;)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
146
Location
England
#10
Lol okay just ran crysis with it in @) alot better fps at the start but then 31 to 40
it was 25 to 30 last time :) yet i know how crysis is so memory intensive etc im gonna run far cry 2 now ;) I wont overclock it then :)
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
146
Location
England
#11
Far cry 2 no aa 1440 x 900 (seems to be hardly any difference in fps of high, very high and ultra high yet i get 25 to 90 fps lol! Average fps is 40 yet when its raining heavily 25 fps :shock:! Im downloading my free batman asylum game through steam while playing yet should that make any diference?
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
146
Location
England
#12
Ah well im happy free batman asylum just downloaded gonna play :)
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
smarteyeball
Eye know, eye know
1,874
Location
Australia
#13
At that resolution your using, your CPU will be holding you back in some games, hence the reason for minimal/major FPS changes.
However, some games are simply more CPU intensive than others, regardless of your resolution.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
archie123
I Tunes hates Me
1,831
Location
UK
#14
yep its not very often i will blame cpu bottlenecking but thats exactly whats happening there mate , at that res your cpu is holding your card back , its a shame you cant bump up the res that card will really come into its own :)
that said running crysis and far cry at those fps your getting isnt too shabby is it :D
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
146
Location
England
#15
yeah :) Cheers guys i ran furmark (lol sorry archie could not resist overclocking a bit :o)
Anyway i found that the shader domain clock would not go up well furmark crashed with it only at 1450 so i just kept it down at 1404 (default) (any explanation)
Clocks are now 723/1404/1257
Is this a good (or normal) furmark score attached!
Just incase no one nos its a asus engtx 275!
    ASUStek
    19inch benq
    1400x900
    400 gb
    Artic cooler
