Packard Bell BV IMEDIA 2215 PB80135701
terryco
Hi, i see there are several cases of audio missing from Pc's and there doesn't seem to be a quick fix. A friend of mine has a Packard Bell BV IMEDIA 2215 PB80135701 32 bit running Vista Home Premium. He wanted to connect the PC to a TV and put a lead with a scart plug on one side into the TV and a jack plug on the other end into the black socket on the back of the PC. The connection wasn't successful but he noticed after there was a red x instead of the speaker icon and a message "No Audio Output Device Is Installed" I dont know if the lead damaged the drivers in any way. In Device manager there are no warning asterisks but some things including speaker stated that there were no drivers. I tried update and was told the drivers are the newest. I have tried driver sites that scan the pc and will update drivers but they want paying. Is there a scan facility in the Packard Bell site that will scan and tell me what drivers i am missing. I have returned the PC back to factory settings via All Programs and i would have thought the drivers would work but they dont. Thanks for any advice
    Acer Aspire T180 R01-A4
    1.80 gigahertz AMD Sempron
    Acer EM61SM/EM61PM
    1280 Megabytes Usable Installed Memory
    NVIDIA GeForce 6100 nForce 405 [Display adapter]
    High Definition Audio Device
    Medion MD32117PQ [Monitor] (17.1"vis, s/n 609001173, September 2006
kesume
You may find this site of some help.
Go to support>search>Drivers for etc> a long list of possibilities are listed.
Hope one of them can help you.
Good Luck.
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
terryco
Thank You. I downloaded the Audio drivers from the Packard Bell site but they didn't work. In the Bios settings HD audio is enabled. I set everything to default but still nothing. I'm wondering if damage has been caused by plugging in to a tv set. Is there such thing as a universal audio driver for Vista or does it have to be as the one thats installed Realtek. I have also noticed in device manager there is no Sound Video and Game controller icon. Its missing
    Acer EM61SM/EM61PM
americancritic
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
hmh1956
My system tray shows a volume control with a red X on it and although my device manager says the device is working properly, no sounds come out, and the volume mixer complains that "no audio device is installed" ; windows vista, 32 bit, Packard Bell laptop 4 years old. I have tried all the "usual" stuff like Device Manager and so on........
The usual stuff - enable/disable, uninstall/re-install, also system restore etc
Nothing of the above works....
Also, since the problem with the sound device started I can´t upgrade to SP2 or install updates for vista.
I have two identical laptops and I have this problem with 1 of them. So...
