Page Setup - Paper Size question
yeknomecaps
I have a Vista 32 laptop and want to use "Monarch Envelope" or equivalent on the Internet "Page Setup." Since "Monarch Envelope" is not in the list - can it be added? If so, how? If not, any idea what the equivalent is? Thanks
judge1974
Are you trying to do this in MS Word?
If Monarch Envelope is not an available option, you might be best off using Custom, measuring the size of the envelope and adding in the dimensions manually
If doing it in Internet Explorer 7, Envelope Monarch (as opposed to Monarch Envelope) should be an available option, though the options differ depending on whatever your default printer is
    AMD x2 Dual Core 3600+ 1.9GHz
    GigaByte GA-M55SLI-S4
    2GB DDR PC2 5300 RAM
    NVidia GeForce GTS 250 512mb
yeknomecaps
Thanks for the reply - I am trying to do it in Internet Explorer 7. I don't have a "Envelope Monarch" nor a "Monarch Envelope" option - I just have multiple "Letter" and "PRC Envelope" options.
judge1974
What's your default printer?
It sounds as though it itself may not support the paper size you are trying to use. If you open something like Word, does it allow you to choose the Envelope Monarch? Meaning, is this paper size available to you in other applications?
judge1974
cool, glad it works
