Paragon Backup ?
560
Location
California
Now that I have downloaded Paragon Backup and completed backup to My Books external hard drive I am stuck on stupid again.:confused:
When going to My Books EH and clicking on a specific file, in fact all files, it goes to Windows Cannot open this file and gives me two choices to use the web to find program to open or use a program listed on my computer to find the correct program to open it.
What is your recommendation?
I have previously down a backup from Vista Home Premium tp My Books EH and don't have any problem opening and viewing these back up files. What am I doing wrong?
Thanks for getting me this far.....just a few more posts and I will be there!
    HP Pavilon Elite
    Intel(R)Core(TM)2 Quad CPU q6600@2.4GHz
    ASUS eK Berkeley
    That's where I keep my beer
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
garysgold
930
Location
Maine, USA
You have to access the files through Paragon Backup. I haven't installed that yet, so don't know if you can select individual files to restore, but the help files for PB should help you there. There should also be an option to create a recovery disk of some kind.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
560
Location
California
I don't want to restore I just want to open the files that were transfered to My Books EH and see what each file has in it. I can't view the PBF files. I need the association/extension program to view it.
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
garysgold
930
Location
Maine, USA
I just got it installed and haven't tried a backup yet, but it looks like the transfer wizard might give you access. Will have a play later and let you know what I find out.
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
560
Location
California
The back up is in arc and pdf files but maybe when you need to restore them back they open up as regular files for windows and Vista Home Premium.
Example: I wear a left handed baseball glove (C drive) and I transfer it to my right hand (My Books EH) and I can't use it BUT when I transfer it back to my left hand (C drive) everything works perfect!
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
SIW2
2,741
You can view and export files from a backup image. Use the File Transfer Wizard, or Volume Explorer from within Paragon.
To view the contents of a file , you need to export it first(copy it back).
Otherwise, you can mount the partition image ( you can't mount file/folder backups - that is different). Within Paragon, select the Archives tab, rt click the archive you wish to mount and mount it.
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
560
Location
California
I ask this question on you announcement of free EASEUS PROGRAMS but as long as I am here let's do it again.
What if any are the differences between MS Vista Home Premium back up and Paragon and EASEUS?
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
560
Location
California
#8
Case resolved......
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
SIW2
2,741
#9
Vista Home Premium backup is only a file and folder backup app. There are plenty of free ones around. This is a popular one:
Free backup software for Windows - GFI Backup Home Edition
There is a completely different kind of backup. It is very important. That is a partition/disk Image backup.
The Paragon and Easeus you refer to are for Image backups.
Image backups are essential if your operating system gets badly infected, or corrupted, or you can't boot in , or the Hard drive fails.
You simply restore the image - either back to the same partition , or if the HD fails - get a new HD and restore the image to that.
In a few minutes you will be up and running with the operating system , all the updates, programs, settings , and any of your personal files and folders. Everything that was on the partition/drive will be restored exactly as it was at the time you made the image.
You can usually also ( as an added bonus ) find and copy back just individual files from the image , if you need to.
Generally, people make occasional Image backups - say once a month.
They do separate file/folder backups more often - once a week ( or perhaps every day if you are writing a novel ).
The reason for that is an image backup is a larger undertaking - you could do one every day, but most prefer to do an image occasionally , then also do selected file/folder backups more often - as it there is much less involved in just backing up a few files.
Hope it helps.
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
560
Location
California
#10
Hope it helps.
Thank you for this info. I am very careful on where I go and what I read and who is sending it so the chances of my comuter being seriously infected or corrupted are slim.
Your explanation of the above differnces are priceless and I can't thank you enough.
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
