Paragon Rescue Kit 9.0 Express
Martee
Vista Die-Hard
584
Paragon Rescue Kit 9.0 Express is free software that professionally fixes boot problems as well as retrieves your data when your system fails to boot. It even rescues deleted partitions. All, you need to do to achieve complete control over any situation is burn the software on your CD/DVD!
Express Key Features:
Worry-Free Data Protection with Paragon's Bootable Recovery CD
Don't wait for disaster strike before using Rescue Kit. Burn the software on your CD/DVD and be prepared for any situation.
Easily Fix Boot Problems
Boot Corrector option resolves various problems you may encounter during the system boot process. These problems may be caused by program errors, user mistakes, or become the results of boot virus activity. Boot Corrector allows you to cure the majority of boot problems for Windows Operating System and gives you access to your data!
Rescue Your Data
In case of a system malfunction, caused either by a virus attack or file corruption, you can retrieve valuable information from your disks and copy it to another local drive, partition or save the data to CD/DVD. The File Transfer Wizard helps you to export data as easy and convenient as possible.
Undelete Partition
When simply deleting a partition (without additional wiping) disk management software only removes the references to it in the Partition Table, thus leaving the possibility to recover it later. The Undelete Partitions Wizard enables you to find and recover these partitions. A restored partition will be fully functional, as long as other partitions were not created, moved or exceeded the disk space.
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
