Partition RAID?
GRock
23
hey i am obviously completely new to this, but i was wondering if it were possible to "RAID" partitions on one hard drive? Say i were to slpit a hard drive into even fourths, could i then set it up to pull data off the partitions as one like RAIDed hard drives?
no specs needed just hypothetical question
lemur
1,533
Location
University of Kentucky
Quick story - I provided consulting support for company with network. Their admin ran backups on the SAME TAPE every night. One night the drive failed while backing up. There's no redundancy in using one tape and they lost everything.
RAID stands for Redundant Array of Inexpensive Disks (now termed redundant array of independent disks). Initially there was one raid, now there are several types.
Raid 0 - Striped disks. Distributes across several disks improving speed. If one disk fails, all is lost (which is why you run backups). It's what I run on my workstation, but not servers.
Raid 1 - mirroring
Raid 5 - striped disks with parity
Raid 6 - striped disks with dual parity
Raid 10 - striping and mirroring
Raid was first envisioned to run with 5 disks. I'm striping with 2, and some require minimum of 3. You cannot run RAID with one disk.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Everlong
To xor or not to xor
1,317
Location
Lancaster University, England.
You can only set it up with 2 or more physical drives. What you have is 1 physical drive and 2 logical drives and won't be able to RAID them.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Sorry GRock, but the answer is No. You can only set up a RAID array on multiple HDDs (minimum number required =2). See http://en.wikipedia.org/wiki/RAID for more information.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
