Pc starts for 10 secs then shuts down
9
Hi all I am having a problem with my pc. It turns on natrually does nto sound like it is having problems but then after 10 seconds it shuts down.
I have tried each piece on an other pc and they seem to be all in working order so next I tried the wiring but it is all connected correctly. I am now stuck do not know what to do can any one help?
2 ATI Rodeon 4870 X2 CrossfireX
ASUS extreme MB (can nto rememebr the model)
The proccessor is a AMD (not sure on model)
Running VISTA
(If the pieces are all working ok then I refuse to buy a new pc so no posts saying "buy new pc")
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
I don't think I've ever recommended someone buy a new PC - though I have recommended taking it to reputable computer respair shop or returning it to the manufacturer for service - but let's hope that isn't necessary here.
Can you boot into safe mode with networking (by booting and during bootup repeatedly clicking the F8 button until the menu appears and then selecting that option)? Does the same problem occur there or does the computer stay on or perhaps at least a little longer? If you can, then that's a good sign and we have more options for finding the problem than if we have only a disk to work with. I've included steps below which assume you can boot into safe mode (and noted where the need to be able to use safe mode begins and where being able to use the disk ends). Do what you can depending on whether or not safe mode works for you.
Do you know when this problem began? Try a System Restore to a point in time BEFORE the problem began. Here's the procedure: http://www.vistax64.com/tutorials/76905-system-restore-how.html. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed and uninstall any software you removed between now and the restore point, but you can use Windows Update for the updates. Use the recovery disk if the system prompt doesn’t work. The recovery disk works a bit different from the above procedures but if you follow the prompts from the System Restore menu option with the above information you should be able to restore with no problems.
If the System Restore doesn't work, do a Startup Repair by booting to the genuine Windows Vista Installation Disk (or one you can borrow from ANYONE) or from a Recovery Disk. Here's the procedure: http://www.vistax64.com/tutorials/91467-startup-repair.html. To boot to the CD you may need to change the BIOS to make the CD-drive first in the boot sequence. To do that, wait for the screen that tells you the F key to push to access the boot menu or boot setup. Push it quickly. Make the changes, save your work, and exit. Put the CD in the drive and reboot. When prompted, push any key to boot from the CD.
If you don't have a disk, you can make a bootable Recovery Disk using http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/ along with burning software like: http://www.snapfiles.com/get/active-isoburner.html and, of course, a blank CD (perhaps with another computer if necessary).
If that doesn't work, try to boot into safe mode (repeatedly click the F8 key while booting and go to safe mode with networking – or do so from the command prompt on the disk). Then let's check some of your system files:
Go to Start / All Programs / Accessories / Command prompt and right click on command prompt and click run as Administrator (you can skip this step if using the disk).
If using the disk, cd to C:\Windows\System32. Type sfc /scannow and enter and let it run. It will scan and try to fix some of your system files. Hopefully it will complete with no corruption it could not repair (if there is such corruption post back here or try to analyze it to find the problem file(s) using http://support.microsoft.com/kb/928228. Try to post any corrupted files here so we can see if they can be repaired with good copies from the installation disk (unless there are too many).
While in Command Prompt, type chkdsk /f /r and enter and let it run. It will want to schedule itself to run at the next restart. Answer yes and then reboot to run the program. It will scan and try to fix any corruption or bad sectors on your hard drive and mostly remove that as a potential cause. This ends what can be done with only the disk. If you can boot into safe mode, please continue - otherwise post back at this point with the results of what you were able to do and the results of the scans you made. This already may have fixed your problem, but if not then read on:
If that doesn't work, then please post any error messages from the Event Viewer concerning shutdown (Start / Control Panel / Administrative Tools / Event Viewer). Here's how to use Event Viewer: http://www.petri.co.il/vista-event-viewer.htm. Look in the System section.
You may be infected with malware. Try to run anti-malware programs (in safe mode with networking if necessary). To fix this problem (if it is a problem) download, install, and run the following two programs: http://www.malwarebytes.org/mbam.php and http://www.safer-networking.org/en/index.html. You may also want to try the new, free Microsoft Security Essentials http://www.softpedia.com/progDownload/Microsoft-Security-Essentials-Download-131683.html (with the caveat that only ONE AV program can be installed and running on your system at any one time - use removal tools when appropriate http://www.raymond.cc/blog/archives/2009/05/05/comprehensive-list-of-uninstallers-or-removal-tools-for-antivirus-software/). You may also want to try the free Avira at: http://www.free-av.com/ and Avast at: http://www.avast.com/index. Reboot after completing all the scans. You may also want to try the free OneCare at http://onecare.live.com/site/en-us/center/whatsnew.htm and let it run all the options (except the registry cleaner) because that’s good maintenance (it will take some time to complete but can be done in the background).
If that doesn't work, try a clean boot http://support.microsoft.com/kb/929135. If the problem goes away then it's just a matter of tracking down the culprit causing the problem. Follow the procedures in the article. Once found, delete, remove, deactivate, or uninstall it. Once done be sure to reset Vista back to normal status as explained in the procedures. If the problem occurs in clean mode then just restore the system to normal status and reboot - this solution is not going to work.
You may be having troubles with your device drivers, firmware, and/or software. Go to Device Manager by going to start / search box and type device manager and enter and then double-click on the program icon that appears. Check each device for a red x, yellow ! or white ?. These identify devices with problems (probably drivers, but also conflicts or something else). Click on each for further details and troubleshooting tips. If you need to get drivers (and you should get any you have time to do - they may help in ways beyond just resolving this problem), do so from the computer vendor or device manufacturer (NOT from Microsoft Updates). Proceed as follows to get the drivers: http://pcsupport.about.com/od/driverssupport/ht/driverdlmfgr.htm. Once you have the drivers, you can install them through Device Manager as follows: http://www.vistax64.com/tutorials/193584-device-manager-install-driver.html. You may also want to try the Driver Verifier Manager to see if you can identify the driver or device responsible (assuming that is the cause): http://support.microsoft.com/kb/244617.
Let's test your hard drive and RAM for hardware problems
To test your hard drive, check the manufacturer and then get the diagnostic utility from: http://www.techsupportforum.com/hardware-support/hard-drive-support/302602-hard-drive-diagnostic-utilities.html (and/or get one from your hard drive or computer manufacturer if they have one available – it wouldn’t hurt to try both). If it fails the test, replace it. If it passes the test, then there's probably nothing wrong with it.
You can also test your RAM at http://www.memtest.org/. If it fails, test each chip individually to find those that are bad and replace them. If it passes, RAM is probably OK.
If that doesn't work, we'll need to do a system repair/upgrade using the genuine Windows Vista Installation Disk (one you own or one you can borrow from ANYONE and only if you can still boot normally). Here's the procedure: http://www.vistax64.com/tutorials/88236-repair-install-vista.html. Although this will not affect your data, settings, or programs, you should still backup your data before starting just to be on the safe side. You may have a lot of updates to re-install (including any service packs you had to remove). If the version on the system came with SP1 or SP2 pre-installed and the disk is an earlier version, then you'll need to make a slipstream disk as follows: http://www.vistax64.com/tutorials/151606-vista-sp1-slipstream-installation-dvd.html.
Hopefully one of these procedures will resolve or at least identify the cause of your problem. If not, post back with results from what you tried and copies of some of the scans and we'll try something else. Post back in any case so we'll know how it turned out.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
9
Can not even get into anyting (safe mode, BIO's etc.) it jsut shuts down. Every now and then if I am lucky it will work for like a day or less
problem started around a week ago only jsut got round to being able to try fix it.
Lorien
Account Suspended
2,212
Location
Then you need to try these options when you do get the machine running (and I'd then leave it on all the time or at least until the problem has been resolved) or take it to a reputable computer repair shop (or return it to the manufacturer) for service. If we can't access the system by disk, safe mode, or normal mode and you've already tried swapping out parts without success, then we have no way to diagnose or repair it.
Good luck!
    1920 x 1200 pixels
    6TO4 Adapter
9
kk thanks
just to comfirm all the links you have recommended you have used yourself and had not had any problems with them like viruses (I know some of them are well known but there are some there I do nto know (all ways good to cheak))
Lorien
Account Suspended
2,212
Location
I have downloaded, installed, and scanned with all of them (though just a little over a year ago when I searched for such products and created the list - I haven't done so since then) - but I have not actually restored with any but Recuva (as none of the others ever found anything recoverable that Recova didn't find and recover).
One other point, I never really confirmed they all worked with 64-bit systems and I see that's what you have (I developed the list with 32-bit Vista in mind), so check to make sure they are compatible (or if they have different download options for the different bit-sizes) before you download them. Once again, I honestly don't think you're going to have much more success with any of the other options if Recuva says the files are overwritten, but you're welcome to give it a try.
Good luck!
    1920 x 1200 pixels
    6TO4 Adapter
