PC tower mods
Matty79
Hi guys,
I have an old tower I want to modify my self. Just going to screw around and make it "uber" lol just for a little fun.
I want to cut out my own pattern in the side and put some perspex in there.
What I want to know is what do you think would be the best tool to use to cut the side out so as not to leave any sharp edges or have it looking dodgy.
TIA for your help.
Use a dremel with a metal bit.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Maybe a router.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Hi matty, and welcome to the forums, :party:
I think the answer here depends on what experience you have with cutting metal and perspex, and also what tools you have available. basically it could all be done using manual tools Drill. saw and files. Obviously if you have access to power tools then that would make things easier. another option is to make friends with your local auto body shop. ;) you do all the design and let them do the cutting
whichever way you decide to go take photographs of the process and post before and after here, I'm sure there are other posters who would love to see this project develop
you may want to have a look Here for some inspiration and even some further help
anyway good luck with the project
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
Hi Barman58,
Thanks for the welcome.
I plan on taking pics as I go along. It is good to document these things not only for others but just for personal satisfaction. This is what I started with and this is the finished project.
I have had a look at that thread and there is some awesome systems in there. Would love to have 4 monitors going lol.
I am going to sit down over the next few days and work out my budget. I don't want to go to high end otherwise I will be broke lol. I want to use it as a basic media centre. I am turning my back room into a little mini theatre.
Will keep this updated once I start and also have a final rpoduct.
