Pentax DSMobile 600 Vista x64 drivers?
Attached is the x64 bit driver. Also attached is the updated software than what came from the CD. You do not need to delete the previous software, it will update itself. The previous DSmobile 600 driver needs to be uninstalled before you install this one. After you download the files, make sure you extract them, double click on the extracted folder, then double click on the setup icon. G2G
View attachment DSmobile600 64bitDriver CD13.zip
View attachment DSmobileSCAN II v2.0.2 SingleFileInstall.zip
