Solved Performance Indicators and % ???
EXOTICA
Hi guys, This might sound like a silly questions but dont burn the newbie to Vista!
I have just set up my two Vista systems and would like to know what the rest of you get as far as your CPU and RAM% are concerned.
On my small Benq joybook it hovers at 55%cpu and 50%ram.
On my Dragon it hovers at 2%cpu and 55% ram at idle.
Any help and info would be great. Ide like to try and reduce the cpu on the Benq obviously as well as the ram on both machines.
Both machine are quite fresh, not really loaded with software. Running N360 on both machines.
Look forward to some help and ideas.
thank you.
can you tell us how much ram you have on both systems and what cpu's your running too?
for the benq you might want to look at what apps are running to take up that much of your cpu at idle as well as the ram. in task manager
for your dragon same thing and are you running dream scene? that chews ram with that on my ram hovers at 50% off it goes to around 30%
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb
    samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
...thanks for the reply mate. On the Benq im funning the Intel Core 2 Duo T5500 1.66ghz and 1.5gig ram on the Dragon Intel Extreme X9000 with 4gig ram.
Not running Dream /scene and yes mines about 30% also.
Vista operates best with at least 2GB RAM. I have 4GB in my machine and it idles around 0% or 1% CPU with Quad Core and about 21% on RAM.
you should add ram to the benQ
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech G11
    Logitech MX-518
gunther's right.....
my machine idles @ 5-10% with dream scene enabled
your benq joybook has a problem....
its either a lac of ram causing the CPU to work far harder....
or as gazz496 stated you may want to check the task manager for a rouge process swallowing power..??
my machine currently has 3gb (1 stick died) & its super responsive
i still maintain low spec laptops should NEVER run vista...;)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech EX110
    logitech cordless optical
    2mb
go with gunthers recomendation for the benq for more ram.
as for the dragon i would be looking at what apps you've got running at startup see if there are apps you don't need that are running.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
I have 4GB of RAM and vista is currently using 1% CPU and 30% RAM. This leads me to believe it takes a little more than 1GB for itself. So if you only had 1GB...>_>.
    Intel QX6600
    EVGA 122-CK-NF68-A1
    4GB Crucial Ballistx PC26400
    8800GTX 768MB
    WD Caviar SE16 WD5000AAKS
    Raptor X 150GB
your welcome. glad you fixed it. might wanna add more ram anyways.
as XP used about 350 or so MB RAM on idle.. and vista uses over 700MB of RAM idle.. thats doing NOTHING.. so you do one thing bigger than opening My Computer and your at all 1GB.. thats why vista should have a "requirement" of at least 2GB in all machines sold with it.
I'd recommend 2GB for sure, and 4GB to be safe.
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech G11
    Logitech MX-518
The RAM usage seems understandable, but the CPU usage is too high for being "idle"...
I'll try to test it later. I'll leave my PC with 1GB and see what happens, I'm pretty sure it won't be 50% CPU...
It would be good to know the processes running when you leave that computer "idle"...
#Edit:
Alright, I've done the test. All fancy stuff on, except DreamScene. Not many things on the Sidebar. No extra software loaded at startup, like messengers, anti-virus and alike.
Basicly, after boot with only 1GB RAM, I've let the computer set for around 5 minutes... (I went to make me some tea and came back)
Memory Usage: 57%
Cpu Usage: 5% Averange, 10% top.
CPU: AMD 3500+ 2.2Ghz (OC 2.7Ghz)
RAM: 1GB
Closing the Sidebar didn't change much what I was seeing, just 1% drop on memory usage.
It was more smooth than what I expected, I think a PC ment for only office tasks could do well with 1GB only. (although putting another GB is rather cheap)
Nevertheless, tried to run Neverwinter Nights 2 and it sounded like it was crying... T.T
  • Other Info
    Windows 7 is love~~
...excellent guys. All is all well now and thanks again. The dragon is now idle at 0%cpu and 35%mem, woohoo. Efficient system. Now for the windows experience index. Benq is 2.5 understandable, the dragon is a flat 5.
How does one now improve on this?
What makes for a better index score?
The dragon is running the X9000 intel, 2x320gig 7200rpm drives, wuxga display and nvidia 8800m gts graphics.
