personalize options missing
SloPpy
hello Window Gods lol...
Ok I Have a problem That I cant seem to shake.
When I right click on desktop and go to personalize, I am missing screen saver, set back ground and windows dream screen. I am not sure what I did but it would be cool if I could get them back I have tried everything I could think of.
Also if i try to set a screen saver by going to control panel it tells me that the administrator has disabled the display control panel ??? I have done no such thing I think. but I can set a desktop background by right clicking on an pic file and telling it to apply as desktop back ground.
Thanks SLoPpy
Brink
Staff member
mvp
Re: personalize opshions missing
Hello SLoPpy, and welcome to Vista Forums.
This sounds like the work of malware. I would strongly recommend running a very thorough antivirus and spyware (ex: Spybot Search & Destroy) scan to help clean your computer.
You might see if a System Restore using a restore point dated before this problem can restore your computer back to normal. I would then run another scan afterwards to be extra safe.
If a System Restore does not help, then these tutorials can:
Enable Control Panel:
http://www.vistax64.com/tutorials/121043-control-panel-enable-disable.html
Enable Desktop Background:
NOTE: You should be able to change back to a DreamScene afterwards.
http://www.vistax64.com/tutorials/107383-desktop-background-wallpaper-prevent-change.html
Enable Screen Saver:
http://www.vistax64.com/tutorials/151020-screen-saver-add-remove-option.html
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome SloPpy.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
