Pixelated screen
dbrogan70
2
Location
Stratford Ct
Hi I am a new forum user and also a bit of a rookie on the Pc I recently bought a new Dell xps 420 w/vista home premium 64bit desktop and I have been getting an occasional problem with a pixelated screen it covers the whole screen with black and white and red squares and the only way I can get out of the problem is shutdown manually as I cant even see the start screen to get to the shutdown or restart can anyone give me any help thanks, DANNY B.
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Dbrogan70, and welcome to Vista Forums.
Your video drivers may have become corrupted. You might see if uninstalling and reinstalling your graphic card and monitor drivers can help.
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
sygnus21
Here to learn
1,033
Location
Hampton VA
Thanks Shawn for the quick response I will let you know how it came out after I find out how to get to the drivers to uninstall them remember I am a rookie thanks again Danny B
Before doing any driver updates you'll need to know what kind of video card you have.
From what you describe, it sounds like video artifacts. The most common cause is an overheating (usually due to overclocks), or a failing video card . They can also be caused by software - bad/corrupted video drivers, or an overclocking. You can see some good examples of video artifacting in this article - Diagnose video card problems by comparing with example corrupted screens.
“IF” that is the case, try updating your video card drivers “after” you determine which card you have. If that doesn’t cure your problem, then considering that the computer is still under warranty (?) I’d have it looked at by Dell.
One other thing to look at is the display monitor. If you have another monitor laying around, see if that one has pixelation when used with your machine. If not, then it could be your monitor that's going bad (or "maybe"...missing drivers).
Good luck
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
dinesh
Vista Expert
1,333
Location
India
Enter BIOS and wait for about 4-5 mins to see if you see the pixels| the best way to check the monitor functionality is remove the data cable from computer and you should see the monitor self test feature check, look for pixels| IF no pixels are found then its an issue with either the video card or OS| then as suggested by Brink, you should update the video card driver|:D
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
