Please Help; I'm Locked Out Completely From My Own Computer
ZoSo0789
4
Okay, my girlfriend is 100% locked out of her computer where she is running Vista Home edition (premium or basic or 32/64 bit I don't know off the top of my head). After boot up and it comes to the Window user account log-in screen, she types in her password as normal, but it's not working. It just says incorrect password...... We KNOW the password is correct (this just started out of the blue), NO one has access to her computer to change or edit the password either, and the reset password link (below the input box) just simply doesn't work. Her account is the only account on the computer and is considered the "Administrator" also. She has no viruses or spyware overload or hackers, or anything simply because her computer has never been on the internet before. Please, she's going away to college this next month and she NEEDS to be able to have a computer, not a $600 paper weight since she'll never be able to afford a replacement. Is this a common problem? If so, what's the remedy? We've tried this, but it hasn't worked for us like it does everyone else. It says that it works whenever we try it, but when we go to log in, it's in the same state as before; nothing REALLY changes Offline NT Password & Registry Editor
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
ZoSo0789
4
None of those seem to be whats wrong. None of the passwords were ever reset, changes, no user accounts messed with, the system can't be corrupted because there's nothing to there TO corrupt it, and theres only one account: the administator account Imagine this: as usual, you shut down your computer and go to bed like any other day. The next morning, you decide to get up and check your messages, but suddenly you just simpy log onto your own computer because Vista says you password is wrong when you know for a fact that it isn't. You sit there and blankly stare for 30 seconds and jus sort of mutter "WTF?????" .... thats what's going on in my case But I'll keep skimming through that link you posted to see what all I can find. Thanks for your help
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
I would still recommend doing a System Restore using a restore point dated when you know it worked. Something went wrong or got corrupted somewhere. It should take it back to that point for you and have it working again.
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
1,823
You could install a new hard drive. Install Vista on it. Take ownership of the files on the old hard drive. Make sure all the accounts have passwords. Create a back door account.
    16GB DDR667
    SAS RAID
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi ZoSo0789,
Have you checked that 'Caps Lock' is not accidentally on and/or, if your password includes numbers and you use the numeric keypad, that 'Num Lock' is on?
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Axon
Beacon of Happiness
Vista Pro
286
Location
Turnhout, BE
Hi ZoSo0789,
Dwarf
My vote goes for that too, I was frustrated that I couldn't log in, but then realised NumLock wasn't enabled :rolleyes:.
Also, there is a way to see how long your password is, if it's equal, the 'Welcome' will take longer to say that it's a false password then when you type a password with less or more letters than the original.
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Razer Copperhead Tempest Blue
    Logitech G15 V1
    100.0 Mbps
ZoSo0789
4
#9
and how can I do that; I've done it to that computer before, but I can't remember how I did because that was quite awhile back
z3r010
Staff member
22,287
Location
Standish, England
#10
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
2
#11
please can anyone help my pc has locked me out of vista it takes me to my user account so i click it and it says welcome and then useually were it takes u to the desktop it logs me back out i cant understand it.Also i havent got system back up as my partned disabled it so im stumped.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
#12
Hello Ozonelayer, and welcome to Vista Forums.
Are you able to boot into Safe Mode? If yes, then you may be able to create a new administrator account from within Safe Mode to use instead.
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
sassofalco
What bad, bad,habit?
Same initial symptoms I had today, and just fixed Shawn. Now I'm also wondering if an update from MS for Office may have kicked this off?
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
#15
Ozonelayer,
Can you copy them directly from within the other account to back them up?
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
