Plese Help "Event ID 46 Crash Dump Initialization failed!"
Status
Not open for further replies.
M
Mark
Log Name: System
Source: volmgr
Date: 12/4/2007 2:48:06 PM
Event ID: 46
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Home
Description:
Crash dump initialization failed!
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="volmgr" />
<EventID Qualifiers="49156">46</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2007-12-04T19:48:06.937Z" />
<EventRecordID>21840</EventRecordID>
<Channel>System</Channel>
<Computer>Home</Computer>
<Security />
</System>
<EventData>
<Data>\Device\HarddiskVolume1</Data>
<Binary>0000000001000000000000002E0004C001100000010000C000000000000000000000000000000000</Binary>
</EventData>
</Event>
qpok
*up*
I get this very same error every time I boot (startup, not shutdown). It appears twice in the system log ("Crash dump initialization failed!" by volmgr with event id 46). I have absolutely no issues with my Vista but I'd like to get rid of this error nevertheless. So far I've been unable to track the source of the problem.
I have SP1 and the latest updates installed.
E
edde
"qpok" <[email protected]> wrote in message
news:[email protected]
> *up*
> It appears twice in the system log ("*Crash dump initialization
> failed!*" by *volmgr* with *event id 46*). I have absolutely no issues
> qpok
After I installed Vista SP1, I noticed two entries in the event viewer after
every boot
Event ID 46 Volmgr Event ID 46 Crash Dump Initialization failed!
I noticed quite a few people have this problem. Here was my solution.
Goto Control Panel\System and Maintenance\System
Click on "Advanced System Settings" on the left panel
Under "Startup and Recovery" select "Settings"
Make sure you have a check mark beside "Write and event to the system log"
I always disabled these settings on XP and Vista before SP1, but it appears
this causes the above error message after Vista SP1 is installed.
This worked for me, I hope it helps somebody else.
G
Grampasmurf
I have it checked but i still get that error. Im also getting a lot of
blue screens talking about crash dumping and i dont know whats causing
it.
Im getting them when i try to play games....Like for example i was on
World of Warcraft..and i noticed a slight lag and then all of sudden my
computer shuts down and boom theres the blue screen. Looks like i only
get it when im trying to play games.
I googled problems like...
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-HttpEvent"
Guid="{7b6bc78c-898b-4170-bbf8-1a469ea43fc5}" EventSourceName="HTTP" />
<EventID Qualifiers="49152">15016</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2008-09-25T01:55:27.499Z" />
<EventRecordID>4139</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="56" />
<Computer>Erwins-PC</Computer>
<Security />
</System>
- <EventData>
<Data Name="DeviceObject">\Device\Http\ReqQueue</Data>
<Data Name="SecurityPackage">Kerberos</Data>
<Binary>000004000200300000000000A83A00C00000000000000000000000000000000000000000000000000E030980</Binary>
</EventData>
</Event>
I read that it has something to do with Service pack 1 for vista. Im
trying to figure out how to uninstall SP1 but i haven't got a way to
uninstall it.
If someone can help me with my problem please tell me how. its really
frustrating.
Also all the events have something to do with
that...if that helps any...
Grampasmurf
Grampasmurf's Profile: http://forums.techarena.in/members/grampasmurf.htm
View this thread: http://forums.techarena.in/vista-help/865120.htm
Status
