Portable HDD
bearchow
Very often, and getting more frequent now, when i plugged in my HDD into my laptop, it hangs and produces a beepng sound. Sometimes it goes away after a while and then it opens, sometimes it just hangs and I have to stop it.
Does problem lie in the HDD or my laptop OS? My OS is Vista Business 32bit.
Any advice anyone? Thanks!:)
    Fujitsu Limited / LBS6410-AMO102EOF1
    Intel(R) Core Duo CPU [email protected]
    2.00GB
MarshallMoore
Try plugging it into another pc with same operating system. If it works fine it's not the hard drive however if it hangs it could be either one and you'll be back where you started from. GOOD LUCK
    HP Pavilion a6460t
    Intel Core 2 Duo E4700 2.6 GHz
    Pegatron Benecia
    4 Gigs
    Nividia 8500GT 512
    HP w2207h 22 inch LCD
    1680 x 1050
JimJoe
You might also try different cables to connect the external to your laptop.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
