Possible to use onboard graphics plus 8500gt
hatehereyes
Power User
my dad has been using an old MX4000 PCI video card for a few years now and he's upgrading to an 8500gt but the problem is when the 8500 is in the system it somehow disables his onboard graphics therefore not allowing him to use his dual monitor set up like he was able to before with the MX4000 and the onboard graphics..
does anyone know a way around this?
    Pentium 4 3.0ghz/ Dual Xeon 2.8ghz 8 cores
    Intel D915GUX
    4gb DDR2 533MHz Memory/4gb DDR2 FB-DIMM
    ATI Radeon x600 Series/ATI Radeon x2600xt
    Dual 19" Gateway FPD1965
    2tb WD
    Velociraptor 300GB WD
    40gb
    Mac Pro - 500gb, 2x 320gb, 150gb
    Country Flag
    usa
    State/Region Flag
    us california
Dwarf
The Contemplator
Hi hatehereyes,
Modern graphics cards are capable of supporting more than one monitor. If the graphics card has 2 DVI-I ports and your monitors are the older VGA standard, you simply need 2 VGA-DVI adapters in order to connect them to the card. Most cards come with a single adapter for this purpose, however you can get the adapters from computer hardware stores. In some cases, you can even get leads with the DVI connector one one end and the VGA connector on the other. The reason why your fathers older video card didn't disable his onboard graphics is because the onboard graphics solution only gets disabled if a video card is inserted into either the AGP slot or the PCIE slot. Your father has been using an older PCI model, and in this case the onboard graphics needs to be exclusively disabled in the BIOS.
Dwarf
  • Name
    Guy
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
    Occupation
    Library Caretaker
    Country Flag
    england
    State/Region Flag
    uk yorkshire
hatehereyes
Power User
ah alright well i'll tell him to just trying using both the VGA and DVI inputs on the 8500gt
thanks.
    Intel D915GUX
    2tb WD
    40gb
    Country Flag
    usa
    State/Region Flag
    us california
ripbox
Nerd
Vista Pro
yes that will sure work this is how i have done it on the past
in fact my current settings are as follows
DVI.1 to DVI on my 32" LCD TV
DVI.2 to VGA on my 17" TFT
HDMI Disabled :(
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
    Country Flag
    uk
