Power calibration error in my dvd writer.
krunal
Hello All,
can anyone help me to solve this error.
i m getting power calibration error when writing dvd with nero.
but i m still able to read cd/dvds.
i have formated and installed new vista but the problem remains,
thanks,
krunal
  • Name
    Krunal
    Lenovo Y410 45Q
    Intel Core 2 Duo
    Intel
    Nvidia GeForce 8400M GS
    160 GB SATA
    Occupation
    Dev
    Country Flag
    india
sidney1st
It could come from:
Old firmware
Bad support (very cheap dvd medias)
DVD writer dying :(
Could you attach the nero log so that we can check exactly what's going wrong.
Is your writer configured as slave?
What is the Nero version?
Anyway, the log will give us all necessary infos
krunal
sure... i will give u the log.
bt using nero 8 and mat-shi-ta dvd writer..
thanks,
krunal
  • Name
    Krunal
    Lenovo Y410 45Q
    Intel Core 2 Duo
    Intel
    160 GB SATA
    Occupation
    Dev
    Country Flag
    india
krunal
Here is the log....
i have write one diff. dvd from writer and it works perfectly. but some media still gives "power calibration error "
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.0.3.0
Internal Version: 8, 0, 3, 0
Recorder: <MAT****A DVD-RAM UJ-85JS>Version: FYX4 - HA 1 TA 0 - 8.0.3.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <MAT****A DVD-RAM UJ-85JS >Version: FYX4 - HA 1 TA 0 - 8.0.3.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
MAT****A DVD-RAM UJ-85JS E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2045MB (2094788kB)
Free physical memory: 1547MB (1584792kB)
Memory in use : 24 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
27.6.2008
Burn DVD Image
10:23:51 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:23:52 PM #2 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x40
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4216061952
CUES:
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <D:\VistaSP1\VistaUltimateSP1A.nrg>
10:23:52 PM #3 Text 0 File Burncd.cpp, Line 3520
Turn on Disc-At-Once, using DVD media
10:23:52 PM #4 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2058623 (457:28.23, 4020MB)
10:23:52 PM #5 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
10:23:52 PM #6 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: MAT****A DVD-RAM UJ-85JS, Media type: DVD-R
Disc Manufacturer: MCC 02 - RG20
Disc Application Code: 64, Disc Physical Code: 193
10:23:52 PM #7 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
10:23:52 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 795
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 2058624 (2058624) = #2058624/457:28.24
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2058624 blocks [E: MAT****A DVD-RAM UJ-85JS]
10:23:52 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 997
Prepare [E: MAT****A DVD-RAM UJ-85JS] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4216061952, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2058624 | 0 | 0x00
2058624 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:23:52 PM #10 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
10:23:52 PM #11 Text 0 File Burncd.cpp, Line 4306
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
10:23:52 PM #12 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
10:23:52 PM #13 Text 0 File Burncd.cpp, Line 4425
Cache writing successful.
10:23:52 PM #14 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
10:23:52 PM #15 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 4x (5,540 KB/s)
10:23:52 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2723
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
10:23:52 PM #17 Text 0 File DVDR.cpp, Line 3227
Recording mode: Sequential Recording Mode
10:23:52 PM #18 Text 0 File DVDR.cpp, Line 3383
Start write address at LBA 0
DVD high compatibility mode: Yes
10:23:52 PM #19 SPTI -1066 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x08f22d00: Len x648
10:23:52 PM #20 Text 0 File Cdrdrv.cpp, Line 9918
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: -
Revision number of minimum recording speed: -
Revision number table of recording speed: - - - - - - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:23:52 PM #21 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
10:24:01 PM #22 SPTI -1106 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 19 25 73 03
Buffer x095f0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10:24:01 PM #23 CDR -1106 File Writer.cpp, Line 312
10:24:01 PM #24 Text 0 File DVDR.cpp, Line 3785
EndDAO: Last written address was -1 (FFFFFFFFh)
10:24:01 PM #25 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 4x (5,540 KB/s)
10:24:01 PM #26 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:24:06 PM #27 Text 0 File Cdrdrv.cpp, Line 11159
DriveLocker: UnLockVolume completed
10:24:06 PM #28 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
  • Name
    Krunal
    Lenovo Y410 45Q
    Intel Core 2 Duo
    Intel
    160 GB SATA
    Occupation
    Dev
    Country Flag
    india
sidney1st
Apparentely it is a media error.
To verify, just burn your DVD on a dvd-rw.
Always burn at half of the max speed of your burner.
Choose medias more like TY labels.
krunal
thanks.
krunal
  • Name
    Krunal
    Lenovo Y410 45Q
    Intel Core 2 Duo
    Intel
    160 GB SATA
    Occupation
    Dev
    Country Flag
    india
westinhoo
hi
im having problems with power calibration errors ,tried diff dvd media discs but not working and tried cleaning lense blowing on it to no avail ...im running vista and its an optiarac drive ...please help...my last log
Code:
[04:57:11] ExpressUI Running Nero Vision Version: 4.9.7.2
[04:57:17] ExpressUI Burn process started by user.
[04:57:17] ExpressUI Destination: Optiarc DVD RW AD-5540A
[04:57:17] ExpressUI Directory for temporary files: C:\Users\malcolm\AppData\Local\Temp
[04:57:17] ExpressUI Available hard disk space for temporary files: 6642.082 MB
[04:57:17] ExpressUI ------<Nero Vision Project Information>--------
[04:57:17] ExpressUI --- Project type: DVD-Video
[04:57:17] ExpressUI --- Project video options ---
[04:57:17] ExpressUI Video mode: PAL
[04:57:17] ExpressUI Aspect ratio: Automatic
[04:57:17] ExpressUI Quality: Long Play (3382 kbit/s)
[04:57:17] ExpressUI Resolution: 720 x 576 (CCIR-601 D1)
[04:57:17] ExpressUI Sample format: Automatic
[04:57:17] ExpressUI Video format: MPEG-2
[04:57:17] ExpressUI Audio format: Automatic
[04:57:17] ExpressUI Encoding mode: Fast Encoding (1-Pass)
[04:57:17] ExpressUI Nero SmartEncoding: Automatic
[04:57:17] ExpressUI --- Project space information ---
[04:57:17] ExpressUI Media type: DVD (4700000000 bytes maximum capacity)
[04:57:17] ExpressUI Total space used: 2.11 out of 4.38 GB
[04:57:17] ExpressUI Space used for menus: 0.5 out of 1024.0 MB
[04:57:17] ExpressUI --- Project contents ---
[04:57:17] ExpressUI Number of titles: 1
[04:57:17] ExpressUI 1. Gullivers.Travels. (Video Title, 1h 21m 00s)
[04:57:17] ExpressUI - Video mode: PAL
[04:57:17] ExpressUI - Aspect ratio: 16:9
[04:57:17] ExpressUI - Quality: Long Play (3382 kbit/s)
[04:57:17] ExpressUI - Resolution: 720 x 576 (CCIR-601 D1)
[04:57:17] ExpressUI - Sample format: Progressive
[04:57:17] ExpressUI - Video format: MPEG-2
[04:57:17] ExpressUI - Audio format: Dolby Digital (AC-3) 2.0
[04:57:17] ExpressUI - Encoding mode: Fast Encoding (1-Pass)
[04:57:17] ExpressUI - Audio SmartEncoding ratio: 0.0 %
[04:57:17] ExpressUI - Video SmartEncoding ratio: 0.0 %
[04:57:17] ExpressUI Number of menus: 1
[04:57:17] ExpressUI - Main menu (1 page)
[04:57:17] ExpressUI --------<End of Project Information>----------
[04:57:17] ExpressUI ------Recording Parameters------
[04:57:17] ExpressUI Book Type: 1
[04:57:17] ExpressUI Destination Device: Optiarc DVD RW AD-5540A (Capabilities: 003AE017)
[04:57:17] ExpressUI Recording Flags: 76
[04:57:17] ExpressUI Recording Speed: 1979168916
[04:57:17] ExpressUI Volume Name: DVD
[04:57:17] ExpressUI Burn-at-once flag: 0
[04:57:17] ExpressUI Fast Update allowed: 0
[04:57:17] ExpressUI --End of recording parameters---
[04:57:36] NeroVision DVD-Video files sorted
[04:57:37] NeroVision Caching of files started
[04:57:37] NeroVision Caching of files completed
[04:57:37] NeroVision Burn process started at 8x (11,080 KB/s)
[04:57:37] DVDEngine BEGIN: VMGM_VOBS - Write
[04:57:37] DVDEngine ...RBP=0, count=135,168 bytes
[04:57:37] DVDEngine ...succeeded
[04:57:37] DVDEngine END: VMGM_VOBS - Write
[04:57:37] DVDEngine BEGIN: VTSTT_VOBS#1 - Write
[04:57:37] DVDEngine ...RBP=0, count=1,073,739,776 bytes
[04:58:03] NeroVision Power calibration error
[04:58:03] NeroVision D: Optiarc DVD RW AD-5540A
[04:58:34] DVDEngine ...succeeded
[04:58:34] DVDEngine END: VTSTT_VOBS#1 - Write
[04:58:34] NeroVision Generating DVD high compatibility borders
[04:58:34] NeroVision Generating DVD borders completed successfully
[04:58:34] NeroVision Burn process failed at 8x (11,080 KB/s)
[04:58:38] NeroVision Process information:
[04:58:38] NeroVision --------------------
[04:58:38] NeroVision Address Version Module name
[04:58:38] NeroVision -----------------------------------------------------
[04:58:38] NeroVision 0x00020000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\AMCDOM.dll
[04:58:38] NeroVision 0x00150000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\GCCore.dll
[04:58:38] NeroVision 0x001E0000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\GCLib.dll
[04:58:38] NeroVision 0x00270000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\GDIPainter.dll
[04:58:38] NeroVision 0x00390000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\AMCLib.dll
[04:58:38] NeroVision 0x00400000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\NeroVision.exe
[04:58:38] NeroVision 0x00880000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\AMCDocBase.dll
[04:58:38] NeroVision 0x00A20000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\MMTools.dll
[04:58:38] NeroVision 0x00AA0000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\AMCUIBase.dll
[04:58:38] NeroVision 0x01FB0000 7.0.74.0 C:\Windows\system32\ImagXpr7.dll
[04:58:38] NeroVision 0x02070000 7.0.495.0 C:\Windows\system32\ImagXR7.dll
[04:58:38] NeroVision 0x02640000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\NeRSDB.dll
[04:58:38] NeroVision 0x026B0000 7.0.74.0 C:\Windows\system32\ImagX7.dll
[04:58:38] NeroVision 0x02960000 6.0.1.6300 C:\Windows\system32\btmmhook.dll
[04:58:38] NeroVision 0x02A10000 7.10.1.1 C:\Program Files\Common Files\Ahead\Lib\ShellManager.dll
[04:58:38] NeroVision 0x02C50000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\DVDUI.dll
[04:58:38] NeroVision 0x02CE0000 10.1.1.10900 C:\Program Files\Common Files\Ahead\Lib\AdvrCntr2.dll
[04:58:38] NeroVision 0x030E0000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\UDFImporter.dll
[04:58:38] NeroVision 0x03150000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\CDCopy.dll
[04:58:38] NeroVision 0x03380000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\DVDDoc.dll
[04:58:38] NeroVision 0x036C0000 1.0.0.21 C:\Program Files\Common Files\Ahead\Lib\DriveLocker.dll
[04:58:38] NeroVision 0x03760000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\DVDLib.dll
[04:58:38] NeroVision 0x04260000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\ExpressDoc.dll
[04:58:38] NeroVision 0x042F0000 2.0.16.0 C:\Program Files\Common Files\Ahead\Lib\NeroFileDialogCF.dll
[04:58:38] NeroVision 0x04300000 2.0.16.0 C:\Program Files\Common Files\Ahead\Lib\NeroFileDialogVista.dll
[04:58:38] NeroVision 0x044F0000 4.6.3.0 C:\Program Files\Common Files\Ahead\Lib\GCHW.dll
[04:58:38] NeroVision 0x04B50000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\GCCapture.ax
[04:58:38] NeroVision 0x04F20000 1.2.4.4 C:\Program Files\Common Files\Ahead\DSFilter\NeResize.ax
[04:58:38] NeroVision 0x055C0000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\GCFX.dll
[04:58:38] NeroVision 0x05D60000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\NeroAPI.dll
[04:58:38] NeroVision 0x06CF0000 4.9.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\NeroVideoFX.dll
[04:58:38] NeroVision 0x07320000 4.7.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\NeVideoFX.dll
[04:58:38] NeroVision 0x07D60000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\ExpressUI.dll
[04:58:38] NeroVision 0x087E0000 0.0.0.0 C:\Program Files\WIDCOMM\Bluetooth Software\btkeyind.dll
[04:58:38] NeroVision 0x088E0000 1.0.0.80 C:\Program Files\Common Files\Ahead\DSFilter\NeroVideoProc.ax
[04:58:38] NeroVision 0x08930000 7.10.3077.0 C:\Program Files\Common Files\Ahead\Lib\MFC71U.DLL
[04:58:38] NeroVision 0x08A60000 2.0.8.5 C:\Program Files\Common Files\Ahead\DSFilter\NeroFormatConv.ax
[04:58:38] NeroVision 0x09120000 4.9.7.2 C:\Program Files\Nero\Nero 7\Nero Vision\GCFilter.ax
[04:58:38] NeroVision 0x0AC20000 4.9.1.12 C:\Program Files\Nero\Nero 7\Nero Vision\DVDEngine.dll
[04:58:38] NeroVision 0x0AE70000 2.1.26.26 C:\Program Files\Nero\Nero 7\Nero Vision\NeroMediaCon.DLL
[04:58:38] NeroVision 0x0D190000 0.7.0.0 C:\Program Files\AVI Movie Player\AC3\ac3filter.ax
[04:58:38] NeroVision 0x0DAB0000 2.2.23.60 c:\program files\common files\ahead\dsfilter\nevideo.ax
[04:58:38] NeroVision 0x10000000 7.0.0.0 C:\Program Files\Nero\Nero 7\Nero Vision\HDCC.dll
[04:58:38] NeroVision 0x13700000 1.0.25.4 C:\Program Files\Common Files\Ahead\DSFilter\NeSoundProc.ax
[04:58:38] NeroVision 0x15000000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\IMAGE.DLL
[04:58:38] NeroVision 0x19000000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\MMC.DLL
[04:58:38] NeroVision 0x1C400000 1.9.0.311 C:\Windows\system32\L3CODECX.AX
[04:58:38] NeroVision 0x20000000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\NeroErr.dll
[04:58:38] NeroVision 0x22000000 7.10.1.0 C:\Program Files\Nero\Nero 7\Core\newtrf.dll
[04:58:38] NeroVision 0x625C0000 6.6.6001.18461 C:\Windows\system32\QUARTZ.dll
[04:58:38] NeroVision 0x63360000 6.0.6001.18000 C:\Windows\system32\D3DIM700.DLL
[04:58:38] NeroVision 0x63800000 6.6.6001.18000 C:\Windows\System32\qedit.dll
[04:58:38] NeroVision 0x63880000 5.0.0.0 C:\Windows\system32\RICHED20.dll
[04:58:38] NeroVision 0x63D80000 6.0.6001.18000 C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll
[04:58:38] NeroVision 0x69B10000 4.20.9876.0 c:\Windows\system32\msxml4.dll
[04:58:38] NeroVision 0x6A0D0000 6.0.6001.18000 C:\Windows\system32\DDRAW.dll
[04:58:38] NeroVision 0x6A9B0000 6.0.6001.18389 C:\Windows\system32\MSVFW32.dll
[04:58:38] NeroVision 0x6C3B0000 6.0.6001.18000 C:\Windows\system32\dsound.dll
[04:58:38] NeroVision 0x6CDC0000 6.0.6001.18000 C:\Windows\system32\ntshrui.dll
[04:58:38] NeroVision 0x6D260000 8.0.6001.19019 C:\Windows\system32\ieframe.dll
[04:58:38] NeroVision 0x6E6E0000 6.0.6001.18272 C:\Windows\system32\DCIMAN32.dll
[04:58:38] NeroVision 0x6E820000 6.0.6001.18226 C:\Windows\system32\wbem\fastprox.dll
[04:58:38] NeroVision 0x6EA20000 6.0.6001.18000 C:\Windows\system32\wbem\wbemsvc.dll
[04:58:38] NeroVision 0x6EC80000 6.0.6000.16386 C:\Windows\system32\LINKINFO.dll
[04:58:38] NeroVision 0x6EC90000 6.0.6001.18000 C:\Windows\system32\wbem\wbemprox.dll
[04:58:38] NeroVision 0x6ED20000 7.0.6001.18528 C:\Windows\System32\msshsq.dll
[04:58:38] NeroVision 0x6F1A0000 6.0.6001.18000 C:\Windows\system32\wbemcomn.dll
[04:58:38] NeroVision 0x6F8E0000 6.0.6001.18000 C:\Windows\system32\ACTXPRXY.DLL
[04:58:38] NeroVision 0x6FC10000 6.0.6001.18000 C:\Windows\system32\thumbcache.dll
[04:58:38] NeroVision 0x6FC30000 6.0.6001.18000 C:\Windows\system32\OLEPRO32.DLL
[04:58:38] NeroVision 0x6FC50000 6.0.6001.18145 C:\Windows\system32\Faultrep.dll
[04:58:38] NeroVision 0x6FC80000 6.6.6001.18000 C:\Windows\system32\devenum.dll
[04:58:38] NeroVision 0x6FCA0000 6.0.6001.18000 C:\Windows\system32\DXVA2.DLL
[04:58:38] NeroVision 0x70540000 6.0.6000.16386 C:\Windows\system32\IconCodecService.dll
[04:58:38] NeroVision 0x709D0000 6.0.6001.18000 C:\Windows\system32\browseui.dll
[04:58:38] NeroVision 0x70B20000 6.0.6001.18000 C:\Windows\system32\SHDOCVW.dll
[04:58:38] NeroVision 0x70C30000 6.0.6001.18000 C:\Windows\system32\D3D9.DLL
[04:58:38] NeroVision 0x71050000 6.0.6000.16386 C:\Windows\system32\d3d8thk.dll
[04:58:38] NeroVision 0x72330000 6.0.6001.18000 C:\Windows\system32\WINSPOOL.DRV
[04:58:38] NeroVision 0x72380000 6.0.6001.18000 C:\Windows\system32\dwmapi.dll
[04:58:38] NeroVision 0x72C70000 6.0.6001.18000 C:\Windows\system32\midimap.dll
[04:58:38] NeroVision 0x72C80000 6.0.6001.18000 C:\Windows\system32\MSACM32.dll
[04:58:38] NeroVision 0x72CA0000 6.0.6001.18000 C:\Windows\system32\audioeng.dll
[04:58:38] NeroVision 0x72D10000 6.0.6001.18000 C:\Windows\system32\AUDIOSES.DLL
[04:58:38] NeroVision 0x72EA0000 6.0.6001.18000 C:\Windows\system32\WINMM.dll
[04:58:38] NeroVision 0x73030000 6.0.6001.18000 C:\Windows\system32\msacm32.drv
[04:58:38] NeroVision 0x73040000 6.0.6001.18000 C:\Windows\system32\wdmaud.drv
[04:58:38] NeroVision 0x73070000 6.0.6001.18131 C:\Windows\system32\WindowsCodecs.dll
[04:58:38] NeroVision 0x73160000 6.0.6001.18000 C:\Windows\system32\cscapi.dll
[04:58:38] NeroVision 0x73180000 6.0.6000.16386 C:\Windows\system32\ksuser.dll
[04:58:38] NeroVision 0x731F0000 6.0.6001.18000 C:\Windows\system32\OLEACC.dll
[04:58:38] NeroVision 0x734E0000 7.0.6001.16503 C:\Windows\system32\PROPSYS.dll
[04:58:38] NeroVision 0x73A30000 6.6.6001.18000 C:\Windows\system32\msdmo.dll
[04:58:38] NeroVision 0x73A40000 6.0.6001.18000 C:\Windows\system32\RICHED32.DLL
[04:58:38] NeroVision 0x73A60000 5.2.6001.18175 C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6001.18175_none_9e7bbe54c9c04bca\gdiplus.dll
[04:58:38] NeroVision 0x73FB0000 6.0.6001.18523 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18523_none_5cdd65e20837faf2\COMCTL32.dll
[04:58:38] NeroVision 0x742B0000 6.0.6001.18000 C:\Windows\system32\uxtheme.dll
[04:58:38] NeroVision 0x742F0000 6.0.6001.18387 C:\Windows\system32\WINTRUST.dll
[04:58:38] NeroVision 0x74360000 6.0.6001.18000 C:\Windows\system32\MMDevAPI.DLL
[04:58:38] NeroVision 0x74390000 6.0.6001.18000 C:\Windows\system32\DUser.dll
[04:58:38] NeroVision 0x74460000 6.0.6001.18000 C:\Windows\system32\AVRT.dll
[04:58:38] NeroVision 0x74530000 6.0.6000.16386 C:\Windows\system32\MSIMG32.dll
[04:58:38] NeroVision 0x74540000 6.0.6001.18000 C:\Windows\system32\POWRPROF.dll
[04:58:38] NeroVision 0x74560000 6.0.6001.18000 C:\Windows\system32\NTMARTA.DLL
[04:58:38] NeroVision 0x745E0000 6.0.6001.18000 C:\Windows\system32\rsaenh.dll
[04:58:38] NeroVision 0x746C0000 6.0.6000.16386 C:\Windows\system32\winbrand.dll
[04:58:38] NeroVision 0x74950000 6.0.6001.18000 C:\Windows\system32\VERSION.dll
[04:58:38] NeroVision 0x74BB0000 6.0.6001.18000 C:\Windows\system32\slc.dll
[04:58:38] NeroVision 0x74BF0000 6.0.6001.18000 C:\Windows\system32\CRYPT32.dll
[04:58:38] NeroVision 0x74D30000 6.0.6001.18000 C:\Windows\system32\NTDSAPI.dll
[04:58:38] NeroVision 0x74D50000 6.0.6001.18326 C:\Windows\system32\MSASN1.dll
[04:58:38] NeroVision 0x74D70000 6.0.6001.18157 C:\Windows\system32\NETAPI32.dll
[04:58:38] NeroVision 0x75020000 6.0.6001.18000 C:\Windows\system32\SAMLIB.dll
[04:58:38] NeroVision 0x75040000 6.0.6001.18000 C:\Windows\system32\DNSAPI.dll
[04:58:38] NeroVision 0x75070000 6.0.6001.18000 C:\Windows\system32\apphelp.dll
[04:58:38] NeroVision 0x750D0000 6.0.6001.18272 C:\Windows\system32\Secur32.dll
[04:58:38] NeroVision 0x750F0000 6.0.6001.18000 C:\Windows\system32\USERENV.dll
[04:58:38] NeroVision 0x75230000 6.0.6001.18000 C:\Windows\system32\comdlg32.dll
[04:58:38] NeroVision 0x752B0000 6.0.6001.18215 C:\Windows\system32\kernel32.dll
[04:58:38] NeroVision 0x75390000 6.0.6001.18588 C:\Windows\system32\SHELL32.dll
[04:58:38] NeroVision 0x75EA0000 6.0.6001.18000 C:\Windows\system32\ADVAPI32.dll
[04:58:38] NeroVision 0x75F70000 6.0.6001.18000 C:\Windows\system32\USER32.dll
[04:58:38] NeroVision 0x76010000 1.626.6001.18461 C:\Windows\system32\USP10.dll
[04:58:38] NeroVision 0x76090000 6.0.6001.18000 C:\Windows\system32\IMM32.DLL
[04:58:38] NeroVision 0x760B0000 6.1.8638.18000 C:\Windows\system32\msvcrt.dll
[04:58:38] NeroVision 0x76160000 6.0.6001.18000 C:\Windows\system32\SETUPAPI.dll
[04:58:38] NeroVision 0x762F0000 8.0.6001.19019 C:\Windows\system32\urlmon.dll
[04:58:38] NeroVision 0x76430000 6.0.6001.18000 C:\Windows\system32\imagehlp.dll
[04:58:38] NeroVision 0x76460000 8.0.6001.19019 C:\Windows\system32\iertutil.dll
[04:58:38] NeroVision 0x76650000 6.0.6001.18498 C:\Windows\system32\ole32.dll
[04:58:38] NeroVision 0x767A0000 6.0.6001.18159 C:\Windows\system32\GDI32.dll
[04:58:38] NeroVision 0x767F0000 6.0.6001.18000 C:\Windows\system32\CLBCatQ.DLL
[04:58:38] NeroVision 0x76880000 6.0.6001.18000 C:\Windows\system32\OLEAUT32.dll
[04:58:38] NeroVision 0x76910000 6.0.6001.18588 C:\Windows\system32\SHLWAPI.dll
[04:58:38] NeroVision 0x76970000 6.0.6001.18000 C:\Windows\system32\MSCTF.dll
[04:58:38] NeroVision 0x76A40000 6.0.6001.18247 C:\Windows\system32\RPCRT4.dll
[04:58:38] NeroVision 0x76B10000 8.0.6001.19019 C:\Windows\system32\WININET.dll
[04:58:38] NeroVision 0x76CE0000 6.0.6000.16386 C:\Windows\system32\PSAPI.DLL
[04:58:38] NeroVision 0x76CF0000 6.0.6001.18000 C:\Windows\system32\WLDAP32.dll
[04:58:38] NeroVision 0x76D80000 6.0.6001.18000 C:\Windows\system32\NSI.dll
[04:58:38] NeroVision 0x76D90000 6.0.6001.18000 C:\Windows\system32\WS2_32.dll
[04:58:38] NeroVision 0x77390000 6.0.6001.18538 C:\Windows\system32\ntdll.dll
[04:58:38] NeroVision 0x774C0000 6.0.6001.18000 C:\Windows\system32\LPK.DLL
[04:58:38] NeroVision 0x774D0000 6.0.6000.16386 C:\Windows\system32\Normaliz.dll
[04:58:38] NeroVision 0x7C140000 7.10.3077.0 C:\Program Files\Nero\Nero 7\Nero Vision\MFC71.DLL
[04:58:38] NeroVision 0x7C340000 7.10.3052.4 C:\Program Files\Nero\Nero 7\Nero Vision\MSVCR71.dll
[04:58:38] NeroVision 0x7C3A0000 7.10.3077.0 C:\Program Files\Nero\Nero 7\Nero Vision\MSVCP71.dll
[04:58:38] NeroVision Book type: 'Automatic'
[04:58:38] NeroVision 1C82-A0K5-19E5-MAAX-400E-M0E1-****
[04:58:38] NeroVision Windows XP 6.0
[04:58:38] NeroVision IA32
[04:58:38] NeroVision WinAspi: -
[04:58:38] NeroVision ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14/03/2007 12:43:16
[04:58:38] NeroVision NT-SPTI used
[04:58:38] NeroVision Nero API version: 7.10.1.0
[04:58:38] NeroVision Using interface version: 7.5.0.1
[04:58:38] NeroVision Installed in: C:\Program Files\Nero\Nero 7\Core\
[04:58:38] NeroVision Application: ahead\NeroVision
[04:58:38] NeroVision Internal Version: 7, 10, 1, 0
[04:58:38] NeroVision Recorder: <Optiarc DVD RW AD-5540A> Version: 2.62 - HA 1 TA 0 - 7.10.1.0
[04:58:38] NeroVision Adapter driver: <IDE> HA 1
[04:58:38] NeroVision Drive buffer : 2048kB
[04:58:38] NeroVision Bus Type : default (0) -> ATAPI, detected: ?
[04:58:38] NeroVision === Scsi-Device-Map ===
[04:58:38] NeroVision CdRomPeripheral : TunePat tpcdrdrv Port 4 ID 0 DMA: Off
[04:58:38] NeroVision === CDRom-Device-Map ===
[04:58:38] NeroVision Optiarc DVD RW AD-5540A D: CdRom0
[04:58:38] NeroVision TunePat Virtual_CD-RW F: CdRom1
[04:58:38] NeroVision =======================
[04:58:38] NeroVision AutoRun : 1
[04:58:38] NeroVision Excluded drive IDs:
[04:58:38] NeroVision WriteBufferSize: 83886080 (0) Byte
[04:58:38] NeroVision BUFE : 0
[04:58:38] NeroVision Physical memory : 893MB (914896kB)
[04:58:38] NeroVision Free physical memory: 390MB (399552kB)
[04:58:38] NeroVision Memory in use : 56 %
[04:58:38] NeroVision Uncached PFiles: 0x0
[04:58:38] NeroVision Use Inquiry : 1
[04:58:38] NeroVision Global Bus Type: default (0)
[04:58:38] NeroVision Check supported media : Disabled (0)
[04:58:38] NeroVision 15.2.2011
[04:58:38] NeroVision NeroAPI
[04:58:38] NeroVision 04:57:36 #1 Phase 111 File APIProgress.cpp, Line 285
[04:58:38] NeroVision DVD-Video files sorted
[04:58:38] NeroVision 04:57:36 #2 Text 0 File SCSIPTICommands.cpp, Line 424
[04:58:38] NeroVision LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
[04:58:38] NeroVision 04:57:36 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
[04:58:38] NeroVision First writeable address = 0 (0x00000000)
[04:58:38] NeroVision 04:57:36 #4 ISO9660GEN -11 File Geniso.cpp, Line 3343
[04:58:38] NeroVision 04:57:36 #5 Text 0 File Burncd.cpp, Line 3508
[04:58:38] NeroVision Turn on Disc-At-Once, using DVD media
[04:58:38] NeroVision 04:57:36 #6 Text 0 File DlgWaitCD.cpp, Line 307
[04:58:38] NeroVision Last possible write address on media: 2295103 (510:01.28, 4482MB)
[04:58:38] NeroVision Last address to be written: 1085439 (241:12.39, 2119MB)
[04:58:38] NeroVision 04:57:36 #7 Text 0 File DlgWaitCD.cpp, Line 319
[04:58:38] NeroVision Write in overburning mode: NO (enabled: CD)
[04:58:38] NeroVision 04:57:36 #8 Text 0 File DlgWaitCD.cpp, Line 2972
[04:58:38] NeroVision Recorder: Optiarc DVD RW AD-5540A, Media type: DVD+R
[04:58:38] NeroVision Disc Manufacturer ID: RITEK, Media Type ID: F16, Product revision number: 1
[04:58:38] NeroVision Disc Application Code: 0, Extended Information Indicators: 7
[04:58:38] NeroVision 04:57:36 #9 Text 0 File DlgWaitCD.cpp, Line 493
[04:58:38] NeroVision >>> Protocol of DlgWaitCD activities: <<<
[04:58:38] NeroVision =========================================
[04:58:38] NeroVision 04:57:36 #10 Text 0 File ThreadedTransferInterface.cpp, Line 793
[04:58:38] NeroVision Setup items (after recorder preparation)
[04:58:38] NeroVision 0: TRM_DATA_MODE1 ()
[04:58:38] NeroVision 2 indices, index0 (150) not provided
[04:58:38] NeroVision original disc pos #0 + 1085440 (1085440) = #1085440/241:12.40
[04:58:38] NeroVision relocatable, disc pos for caching/writing not required/ required
[04:58:38] NeroVision -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1085440 blocks [D: Optiarc DVD RW AD-5540A]
[04:58:38] NeroVision --------------------------------------------------------------
[04:58:38] NeroVision 04:57:36 #11 Text 0 File ThreadedTransferInterface.cpp, Line 995
[04:58:38] NeroVision Prepare [D: Optiarc DVD RW AD-5540A] for write in CUE-sheet-DAO
[04:58:38] NeroVision DAO infos:
[04:58:38] NeroVision MCN: ""
[04:58:38] NeroVision TOCType: 0x00; Session Closed, disc fixated
[04:58:38] NeroVision Tracks 1 to 1: Idx 0 Idx 1 Next Trk
[04:58:38] NeroVision 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2222981120, ISRC ""
[04:58:38] NeroVision DAO layout:
[04:58:38] NeroVision ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
[04:58:38] NeroVision 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
[04:58:38] NeroVision 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
[04:58:38] NeroVision 0 | 1 | 1 | 0x41 | 1085440 | 0 | 0x00
[04:58:38] NeroVision 1085440 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
[04:58:38] NeroVision 04:57:36 #12 Text 0 File SCSIPTICommands.cpp, Line 215
[04:58:38] NeroVision SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
[04:58:38] NeroVision 04:57:37 #13 Text 0 File Burncd.cpp, Line 4294
[04:58:38] NeroVision Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
[04:58:38] NeroVision 04:57:37 #14 Phase 24 File APIProgress.cpp, Line 285
[04:58:38] NeroVision Caching of files started
[04:58:38] NeroVision 04:57:37 #15 Text 0 File Burncd.cpp, Line 4413
[04:58:38] NeroVision Cache writing successful.
[04:58:38] NeroVision 04:57:37 #16 Phase 25 File APIProgress.cpp, Line 285
[04:58:38] NeroVision Caching of files completed
[04:58:38] NeroVision 04:57:37 #17 Phase 36 File APIProgress.cpp, Line 285
[04:58:38] NeroVision Burn process started at 8x (11,080 KB/s)
[04:58:38] NeroVision 04:57:37 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2721
[04:58:38] NeroVision Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
[04:58:38] NeroVision 04:57:37 #19 Text 0 File Cdrdrv.cpp, Line 9869
[04:58:38] NeroVision ---- Disc Structure: Physical Format Information (00h) ----
[04:58:38] NeroVision Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
[04:58:38] NeroVision Book Type: DVD+R (10), Part Version: 1.0x (1)
[04:58:38] NeroVision Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
[04:58:38] NeroVision Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
[04:58:38] NeroVision Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
[04:58:38] NeroVision Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
[04:58:38] NeroVision End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
[04:58:38] NeroVision Data in Burst Cutting Area (BCA) does not exist
[04:58:38] NeroVision Disc Application Code: 0 / 0 h
[04:58:38] NeroVision Extended Information indicators: 7 h
[04:58:38] NeroVision Disc Manufacturer ID: RITEK...
[04:58:38] NeroVision Media type ID: F16
[04:58:38] NeroVision Product revision number: 1
[04:58:38] NeroVision Number of Physical format information bytes in use in ADIP up to byte 63: 56
[04:58:38] NeroVision Media Specific [16..63]:
[04:58:38] NeroVision 00 00 07 52 49 54 45 4B - 00 00 00 46 31 36 01 38 ...RITEK...F16.8
[04:58:38] NeroVision 23 54 37 12 02 50 6E 02 - 8C 68 16 16 0B 0B 0A 0A #T7..Pn.Œh......
[04:58:38] NeroVision 01 1D 1E 0C 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
[04:58:38] NeroVision 04:57:37 #20 SPTI -1065 File SCSIPassThrough.cpp, Line 179
[04:58:38] NeroVision CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1065)
[04:58:38] NeroVision Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
[04:58:38] NeroVision Sense Code: 0x20
[04:58:38] NeroVision Sense Qual: 0x00
[04:58:38] NeroVision CDB Data: 0xF9 15 01 FF 00 00 00 00 00 00 00 00
[04:58:38] NeroVision Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 20
[04:58:38] NeroVision 04:57:37 #21 SPTI -1065 File SCSIPassThrough.cpp, Line 179
[04:58:38] NeroVision CDB Data: 0xF9 14 01 FF 00 00 00 00 00 00 00 00
[04:58:38] NeroVision 04:57:37 #22 Text 0 File DVDR.cpp, Line 7399
[04:58:38] NeroVision Drive: Optiarc DVD RW AD-5540A
[04:58:38] NeroVision Book Type request [gen]: DVD-ROM, write to EEPROM
[04:58:38] NeroVision Changing the Book Type was finished with error, return code -1065
[04:58:38] NeroVision 04:57:37 #23 Text 0 File DVDR.cpp, Line 6780
[04:58:38] NeroVision Book Type request [NEC]: DVD-ROM
[04:58:38] NeroVision 04:57:37 #24 Text 0 File DVDPlusRW.cpp, Line 675
[04:58:38] NeroVision Start write address at LBA 0
[04:58:38] NeroVision DVD high compatibility mode: Yes
[04:58:38] NeroVision 04:57:37 #25 Text 0 File ThreadedTransfer.cpp, Line 269
[04:58:38] NeroVision Pipe memory size 83836800
[04:58:38] NeroVision 04:58:02 #26 SPTI -1106 File SCSIPassThrough.cpp, Line 179
[04:58:38] NeroVision CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
[04:58:38] NeroVision Sense Key: 0x03 (KEY_MEDIUM_ERROR)
[04:58:38] NeroVision Sense Code: 0x73
[04:58:38] NeroVision Sense Qual: 0x03
[04:58:38] NeroVision CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
[04:58:38] NeroVision Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
[04:58:38] NeroVision Buffer x22030040: Len x10000
[04:58:38] NeroVision 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[04:58:38] NeroVision 04:58:02 #27 CDR -1106 File Writer.cpp, Line 303
[04:58:38] NeroVision Power calibration error
[04:58:38] NeroVision D: Optiarc DVD RW AD-5540A
[04:58:38] NeroVision 04:58:34 #28 Phase 127 File APIProgress.cpp, Line 285
[04:58:38] NeroVision Generating DVD high compatibility borders
[04:58:38] NeroVision 04:58:34 #29 Text 0 File DVDPlusRW.cpp, Line 935
[04:58:38] NeroVision EndDAO: Last written address 0
[04:58:38] NeroVision 04:58:34 #30 Phase 129 File APIProgress.cpp, Line 285
[04:58:38] NeroVision Generating DVD borders completed successfully
[04:58:38] NeroVision 04:58:34 #31 Phase 38 File APIProgress.cpp, Line 285
[04:58:38] NeroVision Burn process failed at 8x (11,080 KB/s)
[04:58:38] NeroVision 04:58:34 #32 Text 0 File SCSIPTICommands.cpp, Line 261
[04:58:38] NeroVision SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
[04:58:38] NeroVision 04:58:38 #33 Text 0 File Cdrdrv.cpp, Line 11185
[04:58:38] NeroVision DriveLocker: UnLockVolume completed
[04:58:38] NeroVision 04:58:38 #34 Text 0 File SCSIPTICommands.cpp, Line 424
[04:58:38] NeroVision UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
[04:58:38] NeroVision Existing drivers:
[04:58:38] NeroVision File 'Drivers\ADPU160M.SYS': Ver=6.4.645.100 (NT.051018-1332), size=98408 bytes, created 02/11/2006 09:50:35
[04:58:38] NeroVision File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 24/07/2006 02:00:00
[04:58:38] NeroVision File 'Drivers\PXHELP20.SYS': Ver=3.00.67a, size=43872 bytes, created 20/11/2008 19:19:06 (Prassi/Veritas driver for win 2K)
[04:58:38] NeroVision Registry Keys:
[04:58:38] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
ilikefree
Welcome to the forum,You should really start a new thread as the thread you are on is from 2008.Just click the top where it says "new thread"
  • Name
    Roger
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Occupation
    Tech
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
    Country Flag
    newzealand
