Power Supply - Request for information
rapierau
Im seeking information on a recommended power supply for a system that will probably be replaced in a year so I only want to spend what is required to upgrade not boast.
I have a AMD X2 system running a 3800+ X2 on 2GB ram with two SATA 2 drives, 2x 6" fans plus standard fans, Generic 6600 GPU, on a MS-7100 MSI mainboard. Currently it has a 450w PSU with 18A on the red. Vista Ultimate 32bit is OS
I upgraded my GPU to a Gigabyte GeForce 8600GT 256MB 8600 GT. On installation everything appeared to go well. Then I lost the second core on the CPU and then I got intermittent freezing and failure of the system. No errors in logs, so no driver issue.
I reverted back to the old 6600 and AOK again.
So lack of watts/Amps is the culprit. The question is how much more juice do I need. Do I get a 500w/600w/800w. What do I need to run the card at full pelt without overspending.
Thanks in advance.
This will be able to Handle your System :
Corsair 450W
Pretty Good and Cheap too.
If you want more juice(for future upgrades) ,go for the 520W one or 620W one.
Corsair PSUs have been Rated Excellent by many Reviewers. :)
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
Always go for the biggest you can afford, you can never have enough power.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
