Maetrix
Hi there, I just want to say that I've been quite impressed with the quality of responses I've seen on this forum so that gives me some hope in finding a resolution to difficult problem I ran into here at work.
I apologize for the length, but I wanted to put down as much information as possible. I also wanted to document various solutions I've sought out to save others from retracing my steps.
That being said, heres some background: We wanted to take full advantage of the hardware available in building a production-level computer. It was built 08-Nov-07 and ran fine until about a week ago (18-Jan-08). Then, upon reboot, I received a BSOD with the following error:
Here is the hardware/config:
CPU: Intel Q6700 (8M 1066FSB)
MB: ABIT IP35 PRO
RAM: 4x OCZ DDR2 800Mhz 2gb/stick (Total 8gb)
HDD: 2x WD Raptor x 150GB 10k (Mirror 1 Config)
2x Seagate 1TB SATAII (Mirror 1 Config)
VCD: PNY 8800GTS 320M PCI-E
ACC: PROMISE TX4310 4-Port SATA PCI RAID
OS: Vista Ultimate 64Bit
Initially I figured the problem had something to do with an improper shutdown, but nothing seems to be stabilizing the system. The only way I can get the machine to boot properly was to bring it down to 1 stick (2 GB) of ram as per this thread:
TOP: C0000218 {Registry File Failure): how to fix it in Vista Ulti - Setup and Install
In searching online for the error I came across numerous websites point to this reference page in MS (Which is not helpful for Vista Users):
How to recover from a corrupted registry that prevents Windows XP from starting
Today I found this link: Vista 64 bit and 8 gb RAM - SLI Zone Forums where someone posted:
Now, in the troubleshooting department, what I have left to explore is to see if using Visual Studio 2008 to recompile some old code managed to bugger up the works.
I also got it to successfully boot with all 4 sticks (8GB) when I pulled it from the domain. This was to fix a secondary problem:
As soon as I tried to re-attach it to the domain, I received the c0000218 BSOD again.
All MS Supplied updates have been applied. Is there a known bug with any of them?
So, in short, I'm starting to run out of ideas.
Here's a list of what I've tried:
Using the Auto-Repair via the Vista Disk: No Luck
Using the Restore feature: No Luck
Upgrading the BIOS: No Luck
Downgrading to 2gb: Works
Has anyone else run across this problem yet? Is there any point in calling Microsoft tech support? I'm going to run off and do some more tests on the RAM, wish me luck lol.
With Many Thanks in Advance,
Toby Kliem
IT/IS
Code:
"STOP: C0000218 {Registry File Failure}
The registry cannot load the hive (file)
:\System Root\System32\Config\SECURITY or its log or alternate.
It is corrupt, absent, or not writable."
MB: ABIT IP35 PRO
Seeing as how I am using both in this system doesn't seem to bode well.I sat through the issue with a Microsoft support technician and they are saying that Vista has been having trouble with the Raptor drives and the P35 chipset. Intel has also pointed out there is an issue with certain types of SATA drives as well. Hopefully that helps.
Code:
"The trust relationship between this workstation and the primary domain failed."
Toby Kliem
IT/IS
