I recently had to buy a new computer and got an HP Pavilion a6700f with Vista Home Premium 64 bit SP1 pre-installed. This machine has an AMD X4 quad processor, 4 GB of RAM, a 500 GB SCSI main hard drive, two factory-installed Firewire ports, and a generic IEEE 1394 PCI board with three additional 1394 ports.
On the old system, I had one extra dvd drive and three Western Digital EIDE HDDs connected via Oxford 911 bridgeboard Firewire running under Win XP Pro PS2, through the PCI Firewire card. This setup worked perfectly for four years until the machine failed.
Since getting the new machine, I have had continuing problems with keeping my extra dvd drive and HDDs operating (Code 43). After getting that solved I started experiencing problems with the HDDs not starting (Code 10). The dvd drive is always recognized, starts fine and stays running.
Now my HDDs either will not start or aren't recognized. On the HDDs that don't start, I get a Code 10 error.....with a little more diagnostics I get an error message that Windows can load the driver software, but the software encounters a problem when trying to run. The driver is a Windows driver 6.0.6001.18000, not a third party driver.
I have extensively verified that ALL my hardware is Vista 64 bit compatible, is operating properly, all my drivers are up to date, all cables are tight, etc. In short, I have proven that this is not a hardware failure.
I have even had one dvd and one HDD connected (on different Oxford boards) and operating correctly, but after an overnight reboot, the HDDs cannot be started because of the driver software problem.
The drive manufacturer, Western Digital, refuses to support EIDE drives connected via bridsgeboards to Firewire. No help there.
The computer manufactuerer (HP) is equally clueless and their Tech Support doesn't even seem to understand the problem. They cop-out by saying it's a Microsft problem. And because Vista is pre-loaded, I don't have OEM disks to try a clean install....I can only do a System Restore.
I am open to suggestions.....
- HP a6700f
- AMD Phenom x4
- 4 gb
- nVidia
- Acer
- Hitachi 500 GB
Western Digital WD2000JB
Western Digital WD3000JB
Western Digital WD5000AAKB
- Microsoft Curved Comfort 2000
- Microsoft Comfort 3000
- unknown cable connection
- Other Info
- 4 bay enclosure case for IDE-to-IEEE 1394 Firewire connectivity
Addtitional 3-port IEEE 1394 PCI board
HP dvd1040I Lightscribe drive installed in enclosure case
