Problem with System Restore after using Tutorial.
21
I read the entire Tutorial and thread of "How to Change the System Restore Disk Space Usage Amount in Vista ".
I posted the following in that thread yesterday, but it seems to be a dead thread, so hoping for some help here instead.
This is what I posted in that thread yesterday:
"Just read this thread on 6-4 late pm or 6-5.
I had 2 1/2 weeks of System Restore points on the computer, and that is the amount that I have been holding in my laptop system for years.
I did the check to find out how much space on my hdd is allocated for System Restore, as your article describes.
It is or was allocating about 15% of my 250 gb (230 actually) laptop hdd C drive, as it should be.
Just went into System Restorefor the first time since then just now (6-6) and all of my Restore points are gone prior to 6/4, although as described they were there before I checked for how much hdd space is allocated to System Restore.
This is very disturbing.
I did not alter the amount of space being used when I did the ElevatedCommand Prompt and got the info - I simply "X"ed out of the Command Prompt I believe after it showed me the info.
I have plenty of space available on my C Drive (about 20% available).
I did nothing to use up the available space and cause System Restore to delete older points.
Could simply getting the info via the Elev. Comm. Prompt as you describe in the thread have caused this?
There is another possible culprit - although I have 32bit Vista Home Premium (not Windows ME), I got the Blue Screen of Death on 6-4 in an issue separate from the Elev. Command Prompt (related to using a 1394 Firewire from my laptop to my Ext. Hard Drive apparently, per the Windows Error Message (KB960884 - Stop error when plugging in 1394 disks).
I guess it seems more likely that the deletion was related to this - but - I had the same incident today with the same Error Message - yet as described my Restore points are there from 6-4 thru today 6-6 - i.e., if it was the Blue Screen crash which deleted my Restore points prior to 6-4 when it crashed on 6-4, it did not delete the few Restore points which are still there when the same crash occurred today.
Was going to go in and make sure that the allocation of Sys. Restore space is the same as it was on 6-4 when I looked at the info, but am now hesitant to do so, in case the deletion of the Restore points is somehow related to my doing the Elev. Cmd. Prompt and looking at the System Restore space being used.
Is there any chance that my doing so could've somehow caused the deletion of my Restore points prior to 6-4?
Could the Blue Screen crash (it caused an immediate "Windows will shut down your computer now" msge) have been responsible for deleting the Restore points?
If so, why did it not delete the 6-4 to 6-6 Restore points when the same crash with the same error msge occurred today?
I've been working on a number of system checks on my computer, and may need those Restore points in the future - still tweaking the system - so it's very disturbing to find only 3 days of Restore points on there, and 2 weeks worth have mysteriously vanished.
Any explanations/suggestions will be welcome."
What is much more disturbing is that I just went into my System Restore, and I only have 1 Automatic Restore Point from today (6-8) in there.
Anotherwords, prior to my following the instructions of the Tutorial - issuing Elevated Command Prompt and looking at the details of the space allocated to System Restore, my System Restore always held about 2.5 weeks of Restore Points.
Currently it is holding one day.
Yesterday I did a Vista Defragment of my C Drive, but can't imagine this would cause a deletion of those
Help, please.
SIW2
2,741
Hi Jackson,
It's not easy to read that enormous essay.
If you are asking if simply vssadmin list shadowstorage could delete the restore points, then no, it doesn't.
Unless there is something else going on with your o/s.
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
21
SIW2 - Thought the details would help, but here's the distilled version:
My System Restore has always held 2.5 weeks of restore points.
On 6-6 - it only held 3 days of restore points.
In trying to think of what could've caused this, the ony 2 unusual incidents were:
1) 1 or 2 days earlier, I followed the tutorial to find out the space allocated to my System Restore, by issuing the Elevated Command Prompt.
2) 1 or 2 days earlier, I had a Blue Screen crash, related to a 1394 Firewire/Ext. HD incident.
Today, on 6-8, I checked it, and there are only restore points from today in there.
Only unusual incident was yesterday I started a Vista Defragment, and it took over 12 hours to complete.
So my question is, could any of these incidents have caused my System Restore to delete its restore points?
I'm sure none of these incidents should have caused it, since the restore points are potentially needed after incidents such as Blue Screen crashes (although my system seems to be working ok, other than the Sys. Restore deletions).
Any suggestion re: what could be causing the restore point deletions?
Or what I can do to try to find out the cause?
I ran a successful Check Disk yesterday, before the Defragmentation.
I have enough free space on my C Disk to not have caused the deletions.
