Problem with VGA and Windows Cannot Complete Installation In Safe Mode
ssnick
Hi to everyone!!
I have a problem and i want to give me your knowledge.
I have a HP laptop with a VGA problem and i reinstall the windows with HP recovery and everything goes right untill to come the starting windows logo. when move to the other step after starting windows that it is to setup the drivers of hardware the screen goes black and i can't see anything even with an external monitor.
I try to put it to safe mode but i take the message that i cannot complete the installation in the safe mode. I do the combination with the shift + f10 key and nothing do in safe mode and i cannot open my pc now and i can't disable the VGA card too i don't boot to windows.
Any ideas with that? i appreciate to help me.
Thank's a lot!!
IS the video card an add-on (PCI or PCI-E)? If yes, does the computer have an onboard video connection? If yes, remove the add-on video card and use the onboard until you can load the driver for it after install completes.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
It is a laptop show it isn't PCI or PCI-E VGA. It is an AMD chip on the motherboard but it has an the Intel graphics cards and works perfect. When i disabled the AMD VGA when i restart the windows re-installing again an i have the same problem...blank screen. I have Windows 7 home premium x64 so i can't disable the automated installing drives from Local Group Policy.
Sorry, I missed it being a laptop.
What is the complete model number of the HP Laptop?
One suggestion to try.
Disconnect everything from the laptop, no external connections of any kind (no external mouse, use the touchpad).
Boot to BIOS setup and load Defaults. Save and exit. See if the recovery works any better.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
Need the full model number as I asked for.
HP G62-???? (140US, 240US, etc ...)
Using the built-in recovery should have the right driver. Did you by any chance replace the system board?
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
The built-in Recovery Partition you are doing the recovery from should have the correct driver for Windows 7 for your AMD Graphics device.
It sounds to me like the AMD video chip is defective.
Try a bootable CD/DVD/Flash drive, see what the laptop does then:
See here: Windows 10 Recovery Tools - Bootable Rescue Disk from KYHI
It allows you access to a non-working system - and provides a visual means to repair the system You would have to download the ISO and then burn it to USB or CD to create a bootable WinPE disk.
Also, just realized this thread should really be in the Windows 7 forum, not here in Vista.
Edit: This is the process you are following, right?
On some models, you can perform a recovery from the partition on the hard drive, accessed by
pressing either the Start button or f11. This restores the computer to its factory condition.
To restore the system from the partition, follow these steps:
1. Access Recovery Manager in either of the following ways:
● Select Start > All Programs > Recovery Manager > Recovery Manager.
– or –
● Turn on or restart the computer, and then press esc while the “Press the ESC key for
Startup Menu” message is displayed at the bottom of the screen. Then, press f11 while the
“Press <F11> for recovery” message appears
2. Click System Recovery in the Recovery Manager window.
3. Follow the on-screen instructions.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
